Topic: Turbo Mark VII Time (Read 36636 times) previous topic - next topic
Turbo Mark VII Time
Reply #45
I can now get the wheels and tires mounted up and on the car.
Tires-5891 by Detroit Style, on Flickr
Tires-5890 by Detroit Style, on Flickr
Tires-5888 by Detroit Style, on Flickr
Saved up all week by not having breakfast or lunch and was able to get the front tires mounted.
Tires-5903 by Detroit Style, on Flickr
Now, the motor is ready to go to the shop to be freshened up!
untitled-5915 by Detroit Style, on Flickr
untitled-5907 by Detroit Style, on Flickr
Now the whole top half of the motor will be far to big for the bottom half.
Heads-5922 by Detroit Style, on Flickr
Jason
89 Mark VII LSC- Street Car
12 Focus Titanium - Daily Driver
Turbo Mark VII Time
Reply #46
Next step is to clean up all the packed dirt, install the Team Z suspension, Cobra brakes, eliminate the electric brake booster, remove the rest of the engine harness and remount the intercooler into a new spot I found.
Dirty-6056 by Detroit Style, on Flickr
Got the keys to the new house with a much better garage. I am hoping to get the Lincoln into the garage next week.
It's home!
Well, now I have no excuse. It comes apart this week.
The K is ready to be replaced with a Team Z piece.
Also, what do Mark VII/SVO front 5 lug conversions go for?
Jason
Turbo Mark VII Time
Reply #47
Got the Team Z K member and arms in, I toss the rotors and wheels on to  get a quick idea of what it will look like. On all 4 wheels and with the  motor in it, it should be 3-4" lower that it looks now.
BCN_7528  by Detroit  Style, on Flickr
BCN_7529  by Detroit  Style, on Flickr
BCN_7537  by Detroit  Style, on Flickr
BCN_7539  by Detroit  Style, on Flickr
BCN_7544  by Detroit  Style, on Flickr
Put it on the ground today and simulated ride height with the motor and  turbo kit. It should be another inch to inch and a half lower with the  engine and turbo kit in according to the weights and spring rate on the  font.
BCN_7566  by Detroit  Style, on Flickr
BCN_7561  by Detroit  Style, on Flickr
This has to be the heaviest master cylinder ever now, to make sure it never goes back in by tearing out the rest of the brake system and converting to a standard vacuum assisted brake system.
I am hoping it sits like this when its all said and done.
Jason
Turbo Mark VII Time
Reply #48
I guess, it was time for new rear brakes.
BCN_7569  by Detroit  Style, on Flickr
Why Team Z? Because they are unbeatable.
BCN_7571  by Detroit  Style, on Flickr
BCN_7578  by Detroit  Style, on Flickr
One shock bolt does not want to leave its  home so, its soaking in some Deep Creep for a while. I can't wait to see  the new ride height.
Got the rear springs in today. Once I pull the rack off the other K, clean it up and put it in to the car, the car will be ready to head into the chassis shop.
BCN_7586 by Detroit Style, on Flickr
BCN_7585 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #49
This is one sweet build you have going on
I love those wheels you have on the front, will the rears be chromed too?
Also what made you choose those rear Springs?
Turbo Mark VII Time
Reply #50
looking good, those 275/60's look good in there :burnout:
Turbo Mark VII Time
Reply #51
Quote from: Ramos617;452303
The rears at some point will be the 15" versions for the front wheels but, that is when I get another set of 10.5s for the street.
The rear springs, I am not at the point I want to get too crazy with the rear end, they are great made for the expected weight of the car and the fact that Team Z is local it makes for a great choice.
Jason
Turbo Mark VII Time
Reply #52
As said, sweet build! What the hell camera do you have, by the way?
That heater looks like it will toast that garage up quick! :)
Turbo Mark VII Time
Reply #53
Quote from: DetroitStyle;452312
Cool man, Yea the reason I asked about the rear Springs is because a lot of people including myself use stock sn95 or moog replacement Springs
Looks like Team Z now might have a good alternative for cars with a stock (style) setup
How many inches from the stock height will those Springs drop the rear end of the car
Turbo Mark VII Time
Reply #54
Quote from: ZondaC12;452328
It's a Nikon D7000 with assorted lenses, 99% of the pictures in this thread are done with the Tokina 11-16 2.8 Pro.
I also run BaconMedia which is probably the only reason I haven't sold the camera to fund the car.
https://www.facebook.com/BaconMediaPhoto/
Quote from: Ramos617;452330
In the Mark VII, who knows (I'd guess that is the same response I'd give for the other big body Fox cars). For all I know, they may lift the car from where it was on the coil spring conversion. After talking to Dave (owner of Team Z), I chose them based on the expected weight of the car when its all said and done. At this rate, I may put it on coil overs before that point. :D
 On a SN95 they are said to give 1.5-2" of drop.
Jason
Turbo Mark VII Time
Reply #55
Sweet Mark VII :)
Turbo Mark VII Time
Reply #56
Well, its ready to go to the chassis shop. Depending on how the car sits with the rear control arms that are being made for it, I may go back to the old springs to lower it.
BCN_7639 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #57
So, this one time I tried to put a 100lb 5ft long hood on a car by myself...
BCN_7652 by Detroit Style, on Flickr
BCN_7651 by Detroit Style, on Flickr
BCN_7642 by Detroit Style, on Flickr
BCN_7649 by Detroit Style, on Flickr
BCN_7655 by Detroit Style, on Flickr
BCN_7658 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #58
I have never attempted THAT....I'm 135 lbs soaking wet myself...but I have done many other similar things by myself that I really shouldn't have. And I definitely didn't get away with them all. Most...but not all. When I do stuff I wanna do it NOW. Not in an hour not in 10 minutes, NOW. And I hate bothering friends/family anyway. I need to get past that.
Turbo Mark VII Time
Reply #59
Quote from: ZondaC12;452565
Everyone I know out here (maybe 4 people) were either going to the bar or back to Detroit for Thanksgiving and, it needed done. It is what it is, Ill find a new hood some where and put it on the car.
Jason
