Topic: Turbo Mark VII Time (Read 36466 times) previous topic - next topic
Turbo Mark VII Time
Reply #75
200,000 miles took its toll on the front control arm bolts (all of the suspension bolts really).
PSA: Do not stick your camera this close to a lit torch and oil/grease covered parts.
BCN_7933 by Detroit Style, on Flickr
BCN_7930 by Detroit Style, on Flickr
BCN_7926 by Detroit Style, on Flickr
BCN_7924 by Detroit Style, on Flickr
Someone out there must want a 5 lug conversion for the front of their Mustang... BUY THIS!!
BCN_7938 by Detroit Style, on Flickr
*No cameras or camera equipment was injured during the making for these pictures.
Jason
89 Mark VII LSC- Street Car
12 Focus Titanium - Daily Driver
Turbo Mark VII Time
Reply #76
Are those 315's on a 10 or 10.5" wheel? Looked  good with those on there........
Turbo Mark VII Time
Reply #77
Quote from: flipnbird;453313
10.5" wide if I remember correctly.
Jason
Turbo Mark VII Time
Reply #78
So did the bolts come out in one piece? :hick:
Turbo Mark VII Time
Reply #79
Quote from: thunderjet302;453354
They actually did, one very hot piece.
Jason
Turbo Mark VII Time
Reply #80
Got a sneak peak from the shop last night.
Jason
Turbo Mark VII Time
Reply #81
It's back home! Now, it is time to order coil overs for the rear and get to work finishing the interior and brakes.
BCN_7962 by Detroit Style, on Flickr
BCN_7976 by Detroit Style, on Flickr
BCN_7975 by Detroit Style, on Flickr
BCN_7973 by Detroit Style, on Flickr
BCN_7965 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #82
What no air suspension? ;)
Turbo Mark VII Time
Reply #83
Quote from: thunderjet302;453894
Eff that! Though, I have done that before and I do miss it.
Jason
Turbo Mark VII Time
Reply #84
Quote from: DetroitStyle;453896
Yeah for drag racing the stock Lincoln air springs aren't the best option.
Turbo Mark VII Time
Reply #85
Decided to knock out some work up front, removing the sway bar, removing some lines and some other small details.
BCN_8010 by Detroit Style, on Flickr
BCN_7993 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #86
Started to make new seat brackets for the car.
BCN_8065 by Detroit Style, on Flickr
BCN_8076 by Detroit Style, on Flickr
BCN_8085 by Detroit Style, on Flickr
The hardest part so far, the bracket next to the tunnel has to have a contour made to go around the tunnel.
BCN_8091 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #88
Recently, I had a snow tire let go on the beater and having killed two factory 18s, I decided to order to wheels for it. Downfall, no one had them in stock due to the bolt pattern. Well, the new wheels came in today so, I swapped the tires from the factory 18s over and put them on the car.
BCN_8271 by Detroit Style, on Flickr
BCN_8270 by Detroit Style, on Flickr
BCN_8268 by Detroit Style, on Flickr
BCN_8265 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #89
Now that is a sweet lookin focus
I love the stance that thing has
