Topic: Turbo Mark VII Time (Read 34896 times) previous topic - next topic
Turbo Mark VII Time
Decided to get the interior started since I need to get an engine hoist to pull the motor out, to install the suspension stuff.
Got part of the sound deadening out with nothing more than a putty knife and my hands. Also, that is the insulation from the 1/4 glass area, so much insulation.
Sanchez-4767 by Detroit Style, on Flickr
Insulation on the drivers side.
Sanchez-4770 by Detroit Style, on Flickr
Hello, little guy.
Sanchez-4773 by Detroit Style, on Flickr
No more insulation.
Sanchez-4775 by Detroit Style, on Flickr
When I got the car, only one speaker worked. This may be why, both rears are like this and the cones do not move at all.
Sanchez-4769 by Detroit Style, on Flickr
This had to be in the car since, it was built.
Sanchez-4774 by Detroit Style, on Flickr
Jason
89 Mark VII LSC- Street Car
12 Focus Titanium - Daily Driver
Turbo Mark VII Time
I have  a new game now, it's called what electrical  in the trunk can I throw away. The only things I need back there are the tail lights. The antenna, gas door release and trunk release can even go.
Jason
Turbo Mark VII Time
I'm aiming for 3200lbs or less when its all said and done but, that is still a ways  out.
Jason
Turbo Mark VII Time
It's a baby turbo, measuring in at 70 or 76mm (the 57mm is for the import site that I am on). I have been told its a 76 but, it looks like a 70 either way, its not what I'll be using when the car fires up.
Jason
Turbo Mark VII Time
Well any of those turbos will make block splitting power....i remember that you stated you dont care about that 302.....so game on.
Travis
Turbo Mark VII Time
Reply #39
Let's catch this up a little.
Saying good bye to the electric brake system.
Brake Update-5027 by Detroit Style, on Flickr
The worst part about putting a 4g63 into this car is, figuring out what wires have to stay and which can go. The majority of this harness is for the air ride and brake system which, is all controlled from the trunk.
Harness Destruction-5034 by Detroit Style, on Flickr
Found the headlights!
Harness Destruction-5035 by Detroit Style, on Flickr
Now, I just have to get them out of this mess.
Harness Destruction-5036 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #40
I think, it's safe to say the car may never run again... After taking the sheers to the harness to speed up the harness destruction.
Harness Destruction-5043 by Detroit Style, on Flickr
Harness Destruction-5051 by Detroit Style, on Flickr
Found this in the glove box.
Harness Destruction-5045 by Detroit Style, on Flickr
Got a little work done tonight, the air ride/brake harness is almost out (just need to take it out of the trunk and fish it through to the cabin). Sorted out the last few wires that were in the harness that ran up to the battery isolator and some relays and, removed the blower box.
Harness Destruction-5055 by Detroit Style, on Flickr
It cleans up well but, there is still a lot of dirt built up where the wire harnesses use to be placed.
Harness Destruction-5059 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #41
The Big Bang is over so, I got the air ride/brake harness out of the car.
Harness Destruction-5062 by Detroit Style, on Flickr
Harness Destruction-5064 by Detroit Style, on Flickr
Harness Destruction-5065 by Detroit Style, on Flickr
New luxury seating has arrived.
Kirkey-5109 by Detroit Style, on Flickr
Treadware of 000
Tires-5133 by Detroit Style, on Flickr
Tires-5128 by Detroit Style, on Flickr
Tires-5138 by Detroit Style, on Flickr
Tires-5136 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #42
untitled-5160 by Detroit Style, on Flickr
The engine harness is almost done. I need to find a good route where it wont be affected by the turbo/exhaust and then, loom it up.
untitled-5182 by Detroit Style, on Flickr
I can officially pull the motor to install the k member!
untitled-5185 by Detroit Style, on Flickr
Bacon_Autorama_2015-5801 by Detroit Style, on Flickr
Bacon_Autorama_2015-5806 by Detroit Style, on Flickr
Sorted out the headlights, got the harness tied up and ready for some loom. I still need to figure out the route for the other harness to get it away from the turbo.
Bacon_Autorama_2015-5815 by Detroit Style, on Flickr
Bacon_Autorama_2015-5813 by Detroit Style, on Flickr
Then, the best purchase all year, a new light so I have more than a drop light!
Bacon_Autorama_2015-5820 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #43
Got the dash back in and everything works!
Bacon_Autorama_2015-5829 by Detroit Style, on Flickr
It's the little 302 that could!
Bacon_Autorama_2015-5858 by Detroit Style, on Flickr
Bacon_Autorama_2015-5860 by Detroit Style, on Flickr
Bacon_Autorama_2015-5843 by Detroit Style, on Flickr
Kinda got the seat where I want it, still need to take it to have brackets made for it.
Kirkey-5864 by Detroit Style, on Flickr
Kirkey-5870 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #44
Picked up a free motor, needless to say  I found out why it was pulled out of the truck it was in. One rod is loose and has vertical play at the big end. So, its off to be cleaned and freshened up.
Kirkey-5871 by Detroit Style, on Flickr
Kirkey-5872 by Detroit Style, on Flickr
Kirkey-5873 by Detroit Style, on Flickr
Kirkey-5875 by Detroit Style, on Flickr
Kirkey-5878 by Detroit Style, on Flickr
Kirkey-5880 by Detroit Style, on Flickr
Kirkey-5881 by Detroit Style, on Flickr
Kirkey-5882 by Detroit Style, on Flickr
Jason
