Topic: Turbo Mark VII Time (Read 36513 times) previous topic - next topic
Turbo Mark VII Time
Reply #60
Ouch!! Too bad you're waaaaay up north........ There are like 5 or 6 MK VII's in a yard here.
There are also like 6 to 7 83' - 88' birds and a few same year cougars. No good interiors though :mad::mad:
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Turbo Mark VII Time
Reply #61
Quote from: DetroitStyle;452576
Everyone I know out here (maybe 4 people) were either going to the bar or back to Detroit for Thanksgiving and, it needed done. It is what it is, Ill find a new hood some where and put it on the car.
I swear that's always how it is LOL....
That's it though. Did you screw up? Sure. But you're not doing open-heart surgery. You move on and fix it. Keep kickin' ass.
Turbo Mark VII Time
Reply #62
Quote from: ZondaC12;452590
Really, at the end of the day, that hood was getting trashed anyway. I just wanted to use it to make one out of carbon first.
Jason
89 Mark VII LSC- Street Car
12 Focus Titanium - Daily Driver
Turbo Mark VII Time
Reply #63
Thanks for the tip. I'll remember not to attempt this procedure any time soon :hick:
Turbo Mark VII Time
Reply #65
Interesting. 2.0 Mitsubishi.
Turbo Mark VII Time
Reply #66
The car is now at the shop, awaiting some love.
BCN_7670 by Detroit Style, on Flickr
BCN_7671 by Detroit Style, on Flickr
This should give you guys some hope, the Pacer X is one of his current projects.
BCN_7698 by Detroit Style, on Flickr
BCN_7693 by Detroit Style, on Flickr
BCN_7686 by Detroit Style, on Flickr
BCN_7681 by Detroit Style, on Flickr
Jason
Turbo Mark VII Time
Reply #67
Nice shop :)
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Turbo Mark VII Time
Reply #68
Is that an AMC I6 in the Pacer?
Turbo Mark VII Time
Reply #69
Quote from: thunderjet302;452803
AMC/Jeep, yes.
Jason
Turbo Mark VII Time
Reply #70
Small update, the chassis work has started.
Jason
Turbo Mark VII Time
Reply #71
Wow.
That Pacer is awesome. That's all I have to say.
Is there any strength advantage to going through the floor with the connectors? Would definitely help hide them from sight a bit.
Turbo Mark VII Time
Reply #72
Quote from: ZondaC12;453175
Wow.
There is a benefit just with the material size which, is 2x2 or 2x3 box compared to the 1x1 and some times smaller that you see with the bolt on/weld in kits from pretty much every company. You also see an advantage with the connectors being in the sub frames and being welded not only to the sub frames but, being integrated into the floor, floor braces and the torque boxes. They also get tied into the rockers for even more rigidity.
Jason
Turbo Mark VII Time
Reply #73
I have the Global West lower subframes and Griggs Racing upper subframes on my '83 and I can tell you for a fact that the six point cage made zero difference in the stiffness of the chassis.  You can jack the care up on on corner and the jack will pick the care up to the point that only the far opposite tire is on the ground and the doors will open and close perfectly.  I chose the GW lowers as they go on the outside of the subfame so they do not kill any ground clearance.
Been following this and cannot wait to see the chassis work completed.  I have toyed with mini tubing my car but I am going to see if I can stuff some 315's under it without going to that extreme first.
Turbo Mark VII Time
Reply #74
I'm not sure what the difference is between the Thunderbird/Cougar is and the Mark 7 but, his is my last Mark 7 on a 315. I do have a 325 ET Street in the garage that I want to see if it will fit or not.
_DSC0019 by Detroit Style, on Flickr
_DSC0017 by Detroit Style, on Flickr
_DSC0011 by Detroit Style, on Flickr
_DSC0007 by Detroit Style, on Flickr
Jason
