Topic: Mid/low 13sec 5.0 project (new video and pics 7/11) (Read 249980 times) previous topic - next topic
Reply #270
New flywheel......even better !!!!
Reply #271
Yep...but $90 I wasn't expecting to spend, so I won't have enough to get some nice synthetic ATF.  Got the console piece in today and cleaned it up some.  Should serve well as I look for a mint one.  Less than 24 hours till the big day!
Reply #272
glad your happy with the trans.... my mustang sure misses it!! since the toploader cant go until i find the clutch set up!!
You gonna LOVE that shifter and handle man, i hope some day u can drive a T/C with a stock handle, its horrid compared to what I sold you, absolutely HORRID.
ur lucky I like you lol. That trans has fresh gears, seals, everything.... plus short throw and handle, you made out like a friggen bandit
Reply #273
Definitely man, thanks a ton!  I still *might* use the stock handle for now, but I'm not sure.  I'm definitely going to try both and see which one I like better.
Anyways, only about an hour or so (maybe less) from go time.  Can't wait!  I'll try to keep you all updated periodically.
Reply #274
can't wait to see an end result vid!
1988- 3.8- T-bird- sold 2005 Grand Prix, GTP- COMP.G MODS: Inferno Hood, GXP spoiler, Liquid Metal Wheels,K&N Intake,LED taillights,LED reverse lights, LED interior lights, 180*,605s, Pacesetters :burnout:
Reply #275
you have a stock handle???
you have to mod it to use it , and trust me I drove my dads bird with the ripper handle, and the stock. The stock one just sits to high and its not comfortable to use.
O and another piece of advice, that  I sent you is the stock bird , its a big big and cumbersome. Get a smaller one and it makes it even better.
you wont regret using that handle i promise you. That handle is great for grabing 2nd when your doing hard pulls. I found that real fast!!
1st to second banging that handle in the turbo coupe at 12psi  it was fun! The car didnt like it much though
5th is a little stretch for my little arms but thats the only complaint. And that was on the stock shifter unit, the B&M one has a tighter gear pattern
Reply #276
Oh sweet, guess I'll try the shorter handle first, but the  I prefer doesnt seem to fit right on it...but we'll figure it out.  Anyways, just stopping in real quick during lunch break for an update.  We didnt get a good start till around noon, but with dad working on the interior and my uncle and i working underneath, we're close to having both the tranny and the pedals out.  I'll take pics when we get it all out.
Reply #277
awesome!!! get it done!!!
Reply #278
Alright, well as I said, we got a late start, and the main theme of the day was just a bunch of small nagging things that really kept us from going gung ho on it (anybody that's done a project knows how that goes).  However, we still made good progress that should set us up well to get the car back on the road tomorrow.
Main points of progress:
- The front seat and steering column are out; just need to take out 2 more bolts to get the pedals out.
- AOD is outta there, new rear main seal and pilot bearing are in, along with the flywheel, clutch, and pressure plate.
Anyways, here are the pics I managed to get:
Beginning
Adios AOD!
Underside of car after AOD removal
As the interior sits now:
Underside of car with new flywheel, etc
Reply #279
That's what I like to see.
Reply #280
I gotta quick question:  Is the boot that goes around the fork opening on the side of the bellhousing critical?  I've heard lots of people say that they don't use one.  I don't have one, but should I try to grab one tomorrow?
Reply #281
meh...its not critical. i never used one with no ill results. couldnt hurt having it either if you had one on hand.
~John~
Reply #282
That's something you can always add later on.It just has one small bolt that holds it on.
Reply #283
my dad never ran one with that trans in the stang
Reply #284
I like it just to keep "whatever" out.
