Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1535834 times) previous topic - next topic
Reply #1275
Oh yeah.... shift linkage might look a little rusty too.... hah!  Sorry I'm not nitpicking!
Reply #1276
Quote from: Ifixyawata;271907
Now THAT would've been a helluva better spring compressor to use than the inside-type that I got from AZ.  How much did that thing cost?
Those arent worth a  on our cars. If I ever do springs again I am getting one like Kitz's. Ended up compressing mine, chaining it then shoving it in the car. Bad plan, but it worked.
Reply #1277
Quote from: Ifixyawata;271943
So Kitz.... how much did that big  cost you?
I don't remember, but seen some on ebay for $40, they look the same.
http://cgi.ebay.com/ebaymotors/MCPHERSON-STRUT-COIL-SPRING-CLAM-COMPRESSOR-MACPHERSON_W0QQitemZ190306395951QQcmdZViewItemQQptZMotors_Automotive_Tools?hash=item2c4f25272f&_trksid=p4506.c0.m245&_trkparms=72%3A1171|65%3A12|39%3A1|240%3A1318
Reply #1278
The only problem with this compressor is that you can only compress the spring enough to get it seated in the arm and get a little pressure under it to hold it in.
If you compress it to much, you can't get the thing off the spring because it won't slip back through the coils. and you can't use it with the strut still connected either. There's not enough room for both because of it's size.
So it did help me to the point of getting the spring seated, and keep it from popping back out.
Reply #1279
I thought about modding it a little, but I don't use it much.
Reply #1280
Quote from: daminc;271905
They're pretty cooked . :flame:
So they're not worth it :hick: What about the grill how's that?
Reply #1281
Quote from: thunderjet302;272017
The entire  header panel is gone as of last week.
What else you need?
Reply #1282
Nuts :hick: I don't need anything I just like having spare parts just incase. Could I have the engine block? ;)
Reply #1283
haha
Reply #1284
Quote from: daminc;272106
haha
What are you going to use it or something? ;)
Reply #1285
Jerry, Where did you get the coil spring dampners?? I.E. The red rubber pieces at the top and bottom of coils.
Reply #1286
I got the spring isolators at summit, I think
Reply #1287
Quote from: Ifixyawata;271956
Shift linkage, not staying..... :D
Reply #1288
stick or floor shifter, judging by the parts car and how you said you might keep the aod from the 3.8, I would assume floor shifter.
Reply #1289
Yep, I got a full length console and a complete stock floor shifter and bracket.
