Topic: The '80 XR-7... (Read 48342 times) previous topic - next topic
The '80 XR-7...
Reply #270
Do you know of any that are direct bolt-on (or with minimum mods) to our seat tracks? Basically a pair that don't require... making your own brackets. :)
The '80 XR-7...
Reply #271
Quote from: Ether947;182418
Nope.  Perhaps if you can stumble onto a set of 79-82 Ford Recaros, but other than that it's buy or make your own adapters.
The '80 XR-7...
Reply #272
wow. fresh carpet did wonders for the insides!
The '80 XR-7...
Reply #273
Quote from: Chuck W;182410
Well, the Recaros will be much better, but they are in dire need of a refresh.
Are you gonna try to find the original material?  I'd be curious to see who/where you find that stuff.
pro-five-oh
The '80 XR-7...
Reply #274
Quote from: pro-five-oh;182426
Not sure yet.  Finding the proper "Bittersweet" color is going to be hard enough, much less finding the OEM material.  I'm sure VERY few seats were even done in that fabric.  I'll need to redo the rear seat anyway also, so I may have to improvise.
I actually have 2 sets of Recaros of the same vintage, the original set and a netted halo set (the tan ones).  I may swap the netted headrests onto them as well.
The '80 XR-7...
Reply #275
It took about 2 months to find OEM material to do my front seats last winter. Some guy in Washington State turned out to have some. I doubt Chuck will be able to get OEM material for his seats. If 20 year old OEM material is hard to find try finding 27 year old OEM stuff:hick: . Hell try finding another 80 XR7.......
The '80 XR-7...
Reply #276
Not a whole lot of progress this weekend, but my shift boot showed up on Fri and I took some time Sat to install it and mod the console plate.
The hole is too big in the plate (the existing opening for the little coin tray was kind of wide), so I'll probably take a piece of the black ABS I have to make a finish plate.
The starter dies today too...:toilet: The solenoid is fine (big CLICK when trying to start it), so I'll just find another starter and replace the cable while I'm at it.
Speaking of, anyone have a good used 5.0 starter?
The '80 XR-7...
Reply #277
my friend on FvC does! Its on evilbay, be he will take it off if someone wants it, Its a mini unit he wants 50 for it
http://s127.photobucket.com/albums/p131/nyclsc/For%20sale/?action=view¤t=P1010025.jpg
his name is Nyclsc
The '80 XR-7...
Reply #278
chuck i may have one you can have just pay for shiping ill look later also what about puting up a coverd  tent to store it under dont get rid of it there geting harder to come  by
The '80 XR-7...
Reply #279
Don't need (or want) a mini-starter for this thing.
The '80 XR-7...
Reply #280
Well I was gona say as well I picked up a ford mini starter laying on the ground at pick n pull today.  (Gumby came over :) )
I put it back down because I already have one.
The '80 XR-7...
Reply #281
Quote from: Chuck W;183741
Figured id show you incase you wanted it
The '80 XR-7...
Reply #282
I just don't want to mess with the rewiring on this.
Besides, I have a mini sitting here ;)
The '80 XR-7...
Reply #283
Quote from: Chuck W
Ah yes guys I made custom seat brackets, swapped a 4 speed in, swapped pedals, cut a hole in my floor, designed my own braking system... BUT  THAT ONE WIRE.
Haha Chuck Your hilarious.
The '80 XR-7...
Reply #284
Fine fvckers.
:hick:
I just have to extend the solenoid "exciter" wire, correct?
I guess in the interim, the starter cable can just now attach to the other (battery) side of the solenoid? (Until I get a dummy terminal)
