Topic: 88 sport rebuild , need advice (Read 35941 times) previous topic - next topic
Reply #90
Quote from: jcassity;418592
foe!!!
you sure as hell have resources!
Nah, just the good fortune of working in a Ford dealer with a powertrain table.  It's not a pull method for everybody, but it worked well for me.  I've got a thread on it if you hadn't seen it.  Initially I had some kickback from the board for thinking outside the box, but once I brought pics, people started to get it.
Reply #91
jcassity,
Sounds like you have a good plan!
I ran a set of Total Seal gapless rings when my dad and I rebuilt the original 302 in the Bird back in the late 80's.  That motor was pulled from the car and sold to a buddy and by the time they finally retired his mom's 85 Cougar it had over 200K on the rebuild & never used oil.  The thing you definitely do not want to do is run gapless rings with a power adder.  You can do a Google search on that and it is well documented.
Darren
Reply #92
Xx
Reply #93
tom,,
thank you for the hugs.  :)
now wheres my kisses~!!
Reply #94
Quote from: TheFoeYouKnow;418606
with your method, it offers an opportunity to address corresion in areas we shade tree guys tend not to be able to get to ever.
Reply #95
Tom,
Thanks for the catch!  I should have been a bit more clear on what I was saying.
Tom made comment on questioning how the top ring on the piston controlled oil usage.  I should have clarified that what I was saying about the design of the gapless ring not using any oil was just a thumbs up to the Total Seal ring package as far as longevity was concerned.  We also had the heads serviced with new guides and a valve job so I am sure that contributed to the longevity as well.
jcassity,
I also forgot to mention that your concern with the aluminum roller rockers is something you need not have.  I have the Crane Energizer roller rockers on my Coupe and they have had zero issues and I bought them used.  I am pretty sure that Ford would not have used the Crane aluminum roller rockers in the 93-95 Cobras is there was going to be a longevity issue.  Again, the biggest thing is to upgrade the valve springs like so many here have said.
Darren
Reply #96
Quote from: Aerocoupe;418621
Tom,
Darren
I agree. The aluminum roller rockers are fine. I have FRPP 1.6 roller rockers on my Thunderbird (made by Crane, they are not the Cobra ones but the blue 1.6 ratio) and they are beefy pieces. If you are going to buy roller rockers stick with name brands (FRPP, Crane, Comp) as they make quality aluminum roller rockers. DO NOT use the cheap, less than $200, aluminum roller rockers from eBay/China. There is a reason they are half the price of the quality ones.
Reply #97
You need a slight amount of blow by in position ONE.
Reply #98
i was going to buy parts today but,, now springs came  up.
i was under the impression that only the GT40P heads needed valve spring upgrade, the GT40 springs do not.
sprngs are not on my list.
tom
you against gapless all together? cyl1 takes a beating i know but is your reason because its the ref cylinder ?
Reply #99
i got an HO cam, measured all the journals and they look good.
main journals mic out at
1- 2.0815
2- 2.0659
3- 2.0511
4- 2.0363
5- 2.0210
50% of the lobes measure on average 1.7278
50% of the other lobes measure on average of 1.7178
i measure a lobe journal width and subtract that number from the above height and am coming up with about .2xxx remaing
I was expecting to have .444 on average remaining since someone earlier said this number.
also havng trouble verifying the cam lobs profile matches the ho firing order, im rotating it on the work bench CW
what marks do i look for to confirm it is an HO ?
Reply #100
Im pretty sure it is scott. If it turns out to be a so cam ill refund you no questions asked. But im sure the motor came out of a 91 mustang
Reply #101
no issues, just verifying the one part you dont want to install without being sure,, it is a good looking cam.
Reply #102
that sounds about right. you have to remember that you have 1.6:1 rocker arms. The actual lobe lift will be less, .444 lift is at the valve.  Measured lobe lift x 1.6 should be in the neighborhood of .444.
Reply #103
last night we mic'd out the cam,, today we took the delivery of the used 133,000 mile explorer motor.
its nice to see mason and chance working together.
verified heads have three hash marks,, they are GT40's.
