Messing around with 3D printing Reply #30 – August 16, 2013, 05:18:22 AM shifter would get in the way . Quote Selected
Messing around with 3D printing Reply #31 – August 16, 2013, 03:45:47 PM How about a blank panel to snap into the dashboard clock housing? I just started a thread for ideas on what to use this hole for, but 3d printing a blank panel would turn the clock housing into a project box and the options would be far wider. Quote Selected
Messing around with 3D printing Reply #32 – August 17, 2013, 07:56:52 AM Foe, what about making these door handle parts?If you don't have them, I can measure mine and draw a sketch. This should be easy for you, what do you think? Quote Selected
Messing around with 3D printing Reply #33 – August 17, 2013, 08:05:11 AM Center consoles and trim. Maybe the center piece that houses the seat, mirror and window buttons. You could change things up a bit and make provisions for extremely thin breakthroughs for lighting of letters and lines and stuff or make it out of a clear chunk of acrylic or whatever. Then, paint or cover most of it but leave certain features uncovered and light it from underneath or the edges or whatever. That stuff can have the light source on the edge or somewhere but will radiate evenly throughout. We have a lot of little clear plastic parts throughout the dash components that do that very thing but on a smaller scale.The door lock buttons too maybe. Quote Selected
Messing around with 3D printing Reply #34 – August 17, 2013, 09:41:52 AM Quote from: Cougars 2 go;420187...make provisions for extremely thin breakthroughs for lighting of letters and lines and stuff...It can be done with the original bezel... with a new face plate and some ghetto engineering! Quote Selected
Messing around with 3D printing Reply #35 – August 17, 2013, 09:42:58 AM By the way... I love this thread! Keep up the good work! Quote Selected
Messing around with 3D printing Reply #36 – August 17, 2013, 12:28:13 PM Quote from: BLeavitt23;420190It can be done with the original bezel... with a new face plate and some ghetto engineering!How much for one in green (to match the rest)? Quote Selected
Messing around with 3D printing Reply #37 – August 17, 2013, 04:54:47 PM Support arm is done... Quote Selected
Messing around with 3D printing Reply #38 – August 18, 2013, 08:00:17 AM Hey, can these things create stuff out of wood? Quote Selected
Messing around with 3D printing Reply #39 – August 18, 2013, 08:19:00 AM How about making those little interior door handle cups! Hey, we all need those and they are small enough to churn out with this!And the power seat recline button shroud that runs along the outboard side of the front seats. Is that small enough for this printer? Quote Selected
Messing around with 3D printing Reply #40 – August 18, 2013, 08:25:53 AM I just realized you are sending files out to Shapeways. I'll have to go check them out to see what the limits are. Quote Selected
Messing around with 3D printing Reply #41 – August 18, 2013, 08:38:29 AM Quote from: Cougars 2 go;420216Hey, can these things create stuff out of wood?No, lol. Quote Selected
Messing around with 3D printing Reply #42 – August 18, 2013, 04:16:01 PM Quote from: Cougars 2 go;420220I just realized you are sending files out to Shapeways. I'll have to go check them out to see what the limits are.I plan to make them separately available for download, but I didn't want to do that until I can verify that everything is correct. Once I have a complete cupholder from Shapeways using all printed parts I can be sure of that. I'll make the ones that I've verified so far public on their site.I just finished the internal left and right guide pieces and ordered a set. I altered the design in an attempt to make it more robust. The last part to model is the sleeve itself, which won't be cheap to print. Quote Selected
Messing around with 3D printing Reply #43 – August 27, 2013, 08:50:03 PM I got a few more pieces and they were close enough that I made the revised models available on Shapeways. The only piece I have left to model is the sleeve itself. I made some mistakes on my bezel model so I'm waiting for the revised one to arrive in the mail before I can sign off on it. The tray, support arm, pin holder, and inner guides are all A-ok, though.The inner guides take thin metal strips as springs; the idea is that they push up on the tray sides to give some tension. Just about anything a little stiff will do, though. In this pic I gave clear plastic strips cut from plastic packaging a try and they work fine. Quote Selected
Messing around with 3D printing Reply #44 – August 27, 2013, 10:55:49 PM you need a reprap or a makerbot.you could have built one for what you paid for these peices. Quote Selected
