Topic: Show off the little stuff! (Read 111647 times) previous topic - next topic
Reply #90
XR-7 emblem on my Subwoofer box.
Reply #91
Light Candy
Sorry I'm not a good night photographer. No picture.
I just mounted som electroluminescent wire behind the midconsole bezel, around the radio and a/c controls.
Easily done and WOW what a nice effect! It looks Like a real expensive airplane pen 15pit.
I was unhappy about not finding my buttons at night, thought about Leds but I'd need a bunch of them.
Then I remembered the PC case mod stuff I'd seen. You can see their stuff at
 http://shopping.netledger.com/s.nl/c.ACCT76399/sc.1/.f
Best buy is the PC mod kit, just cut off the PC connector and stick the light pipe wire on behind the bezel.
I used double sided tape. Space the bezel out an 1/8 inch to give the best lighting.
I used the ultra marine color but I think that the lime green would match better with the rest of the dash lights.
Aha! if only I'd learned puppiesanese, the little  with a moon and stars means night pictures!!
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
Reply #92
piston shift , cougar emblem on door, and the halo headrests.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Reply #93
Taurus heater conversion, rear window defrost switch and trunk mount battery.:D
Reply #94
I had a little extra material from the decals I had done, so I decided to fill in the centers of the TBirds..
new engine
Reply #96
I think it counts as a small thing! I also had the dash and radio bezel in the SHO painted the same color as the car.
Reply #97
Painted the dash suround metalic charcoal like the lower body paint and added a few things to the ashtray cover on the dash center stack:D
Reply #98
Sandblasted, Painted and polished the intake plate
Reply #99
This aint exactly cosmetic or cool lookin but it sure the hell is functional. I had a tail light lens separate from the rest of the assembly on the freeway for the second time. Happened on a TC I owned a while back too. Well, it's gettin harder to come by these lights. This one took a month to find. So I decided that this was never going to happen again. I drilled 3 small holes and used some extra interior sheet metal screws I had and secured the 2 pieces together. I'll never lose another lens!!!
Reply #100
think about painting that body color? looks nice, iv pulled em off by hand before while trying to pull out the dissconnected assembly from the back of the car lol, so i can see how they just fall off on the highway.
Reply #101
I just installed this mirror.. Its an auto dimming mirror off of a 89 thunderbird. And yes it works!  :D
Reply #102
Did it just plug into the little ball joint, or did you have to replace the whole mount?  AKA were you able to keep the autodimmer/auto headlight sensor?
Reply #103
The whole mirror assy. was replaced. new pic
Reply #104
very nice! :D
