Topic: Show off the little stuff! (Read 111793 times) previous topic - next topic
Re: Show off the little stuff!
Reply #60
Quote from: CougarSE
Chuck I see why you don't have time for our motor mounts!  Your to busy building that f'n sweet looking bird!
Hell the motor mounts are part of the reason I can't get it finished  :crazy: I should show you the piles of motor mount stuff I have in the garage waiting to be finished and to get to the plater.  I was supposed to work on the cage last weekend, but of course it rained all day Sunday when I was planning on working on it.  I'm going to try to get some time with it this weekend though.
Reply #61
 chuck, that is one  sweet looking bird.
Reply #62
Well, I promised some new trivial pictures after work today, so here goes. As always, my camera sucks.. this is the best I can do with it.
Got some fog lights put on the car awhile back, since neither of my Marks have the stock lights on them anymore. Hooray for $20 AutoHole gift certificates and rewards programs. The first two pics also show the grille I painted last night. Two hours of taping, four hours (off and on) of messing with paint, and I'm still not happy with it. Anyway, instead of going black with it, I went with the dark blue that is going to become the main trim color on the rest of the car. (which you'll see a little more of later)
Third pic is that same blue color again, although not a very good job of it. (it tends to show light unless I really pack it on there.. and I just did this to clean 'em up a little) Painted the air vent grilles underneath the wipers.
Reply #63
In the next pic, you can see I started on the mirrors. I painted the plastic trim rings, and eventually I am going to paint the middle plastic ring (where the mirror mounts to the body) on the mirrors from the '88 and swap them over.. or just tape these off and paint them on the car. Anyway, the mirrors were where I first got the idea to do dark blue trim vs. black.. and now it's taking off to include much of the car.
Last two pics are my new gauges. py SunPro gauges, but they serve their purpose. Unfortunately, the Mark's dash is so cramped for space, (without tearing something up) I had to mount the gauges facing upward toward the windshield. Not the most convenient thing, but it involved the least amount of dash mutilation. Someday I will go back and rework everything, if and when I find a better solution. I was thinking of some kind of raised metal frame that mounted over the top part of the dash without touching it. Since the top of the Mark dash appears to be a separate piece, I'm thinking I can just mount that frame at the seam you can't see when you're sitting in the seat. Hard to explain. I'll mock it up someday. Anyway..
Left two gauges are water temp. and volts.. the green switch on the cluster is the master power switch. If I shut that switch off, you can't light the extra gauges, and the voltmeter dies. There's a 5A fuse just below that cluster. You can also see a red toggle for the fog lights, to the right of the voltmeter.
Right two gauges are vac/boost and oil pressure. The blue switch (all these are lit, btw) controls the gauge lights. This is something I intend to eliminate eventually, when I put the gauge lights on the dimmer. (go fig.. these gauges are too bright, my others are too dim) For now, though, this was the solution that gave me the smallest headache to install.
Reply #64
Having posted that, let me remind everyone that this is not meant as a fishing-for-praise type thread, or anything like that. (at least, I don't mean it that way.. don't care if that's your motivation or not) It's meant to try to inspire other people, if they need inspiring. It's meant to give other people ideas, if they need or want ideas. Hell, if nothing else, you might be wondering if someone else did a mod you're considering and haven't seen mentioned before.. and might see it here.. and it might help you decide whether or not to continue.
Reply #65
Quote from: TurboCoupe50
My newly installed, but used, cold air setup. I've insulated it with some header wrap,(cool factor). No I don't know it it helps, car actully seems to run same as it did with the stock air box and a K&N filter.
It very well might help...I originally had my upper intercooler pipe as just bare steel, until I found out just how freaking hot it gets where it goes over the exhaust manifold (hot enough that you can't touch it, I know that much). I wrapped some thermo-tec heat shielding around it, and now you can put your hand on the outside of it even when the car is running. Much better. Of course, it probably also helps that before the pipes were black, and this insulation has reflective foil on the outside of it.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Reply #66
PLEASE sticky this post!!! This is the first time I've seen it and it gave me a ton of ideas. Great for quick reference!
Reply #67
Wow, y'all listened to me? Don't do that too much, I might get a big ego inflation and try to start my own company or something :D
Reply #68
i dont have much in the name of little things, other than my little "non-smoking" mod
Reply #69
I think I have a few.  Right now I'm thinking about what I did to the shifter, this may not be that uncommon:  I've seen where people replaced the shifter bushings with solid bushings, but I didn't want to buy any parts so I simply took the upper shifter handle off and pulled the metal shoulders (sleeves) out of the bushing holes.  You have options, I just threw one in the black holes somewhere and I cut the other sleeve in half.  Now use the halves to go back in the bushing holes and put it all together and tighten the bolts down as much as you dare.  This will take all the sloppiness out of the shifter but still dampen vibration.  Or you could just shorten the shoulders the desired amount to tighten things up.
I may experiment with doing away with the rubber part and using nuts to bolt the shifter directly to the base bar, but it works great as is, much tighter feel.  The only thing to do is replace the soft factory  with a hard material  for even better feel.
I have more, just can't think right now.
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
Reply #70
For the seatbelts, I thought about making some metal sleeves somehow or another to replace the factory plastic "thingy".  Some stainless sheet metal would make a sweet sleeve, just need to mount it so it has some flex to it and doesn't bend.
84 SVO
88 TC
87 XR4Ti
Reply #71
That would be schweet, but you'd have to be sure it couldn't cut the belt in case of an accident
Reply #72
Quote from: Aerobird Motorsports
I'm glad that it's finding use under its intended purpose.
Reply #73
5.0 badge :hick:
