Topic: Show off the little stuff! (Read 111765 times) previous topic - next topic
Re: Show off the little stuff!
Reply #45
Hehe, figured I would note all the .
Reply #46
Figured I would outdo myself.
Reply #47
I finally removed the seatbelt 'thingy's' from my parts car and meant to bring them in tonight to see if our current sleeves or some of our 'obsolete' sleeves will fit. Guess I forgot. They will have to be painted, but at least maybe we can all have good ones. We have black and a dark grey, but everything else will have to be painted. I'll post replt romorrow to let everyone know if we can get them.
Reply #48
Ooh, interior stuff!  I almost forgot.
I DO have to either find a right side smoke grey sun visor without a rip or reupholster mine....
Reply #49
Paul, that color combination kicks ass! Very nicely done. PM me about the visor.
I've put the seat belt info we talked about a few days ago in a new thread here: http://www.foxtbirdcougarforums.com/showthread.php?t=3611. Be sure to check it out...post feedback please.
And I got a chance to get a photo of another mod:
Custom Cobra intake plate, one-off.
Reply #50
Eric how did you have that plenum plate made?
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Reply #51
Quote from: blownbirds
Ancient Chinese secret...  :grinno:
I will say that I hand-formed the metal.
Reply #52
Thread to be revived tomorrow with pics, after I get home from work. Figured I'd bump it while I was digging around for old posts. :p
Things might pick up now that I actually have money to work on these  things. :p
(and the revival won't have anything to do with upper intake plates, I promise) :D
I did the plastic trim rings on the Mark's side mirrors, and I'm painting the grille tonight.
Reply #53
Painted over the woodgrain on the dash with magenta/gold color changing paint. It almost matches the car color, also painted the turbines gunmetal. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Reply #54
A better shot of the NACA duct installed on the TBird.
Reply #55
Little stuff ya say?
Well, here's a shot of my valve cover...it's one of the early turbo ones (best of the bunch IMO). Painted the sides with wrinkle black, then masked the top and painted the main part the same color as my car, and did the Ford emblem in metallic blue. Then I sanded down the raised parts. Turned out pretty nice but now that it's on the car, I dunno how I'm gonna be able to keep it clean. I also painted my upper & lower intakes with wrinkle black and painted the throttle body black and accessory brackets black for a little different look.
Also got a shot of the gauge panel I have in my EQ hole.
I should also get a picture of how I put the controls for my reverse indiglo gauges in the "blank" spot where the controls for the autodimming lights would be. Blends right in. I also stripped the peeling black paint off my aluminum door lock surrounds (so it's bare aluminum) and that thing in the center console but it didn't turn out as good as I thought it might look. OH, I also put some aluminum sill plates from an '84 Thunderbird in my car, they look way cooler than the factory plastic ones.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Reply #56
I like the look of the black bracketry on the negine.
Reply #57
I may as wel add a few more things I've done to my car since I origially posted in this thread. In addition to the stuff mentioned earlier:
  • TC cluster with Canadian 220k speedo and tach modified for 8cyl
  • Shiny chrome cluster bezel (the $10 ebay one)
  • Tripminder computer
  • Explorer overhead console with temp/compass display
  • Fog lights in front bumper slots operated with factory TC switch
  • '83 Cougar console (the full length one) with restored switch plate
  • And some electrical stuff (stereo system, sequential turn signals, wigwag headlights, remote keyless/alarm/start
  • Police Interceptor emblem
  • minor exterior bits - tinted glass, ventvisors, etc
  • Restored/refinished 10-holes with T-Bird centers
I've since done:
  • Grant GT steering wheel with cruise buttons relocated to dash panel
  • Front seats reupholstered, broken seat belt thingy replaced, and driver's door armrest replaced
Reply #58
My newly installed, but used, cold air setup. I've insulated it with some header wrap,(cool factor). No I don't know it it helps, car actully seems to run same as it did with the stock air box and a K&N filter.
Reply #59
Chuck I see why you don't have time for our motor mounts!  Your to busy building that f'n sweet looking bird!
