Topic: Dpfe (Read 6714 times) previous topic - next topic
Dpfe
Friends, is an honor to engage in dialogue with you.
I write this day with great joy, because I could get one ecu for my cougar ls 1987.
Now trying to give a second life to this beautiful car.
to install these parts I thought the car would start.
did not happen.
and to test KOEO codes are as follows ...
Code 31: Solenoid E.G.R. -
Code 51: Water Temperature Sensor (high signal) .-
Code 68: Air Temperature Sensor (low signal) .-
Code 81: Failure in the fan eletric .- (¿Radiator fan?)
Code 82: solenoid air bypass the catalytic converter is defective in the circuit .-
Code 83: Fan high (faults in the circuit) .-
Code 89: converter clutch solenoid .-
Every time I think I'm closer to revive the cougar ...
I also believe that the fault may be the DPFE.
because I believe that:
codes 51 and 68 => are related to EGR
codes 81 and 83 => electric fan was remplasado by one on the belt pulley
codes 31 and 82 and 89 => DPFE
you know the location of the component DPFE
if you can guide me will appreciate it.
regards
ACCEPT
Dpfe
http://sbftech.com/index.php/topic,588.0.html
Efi no start troubleshooting.
I know english is not your first language. If you can follow all of the steps there, you should know what you need to do to get it to start.
Dpfe
I will.
thank
Dpfe
i can't found DPFE in my 3.8 cougar... it's DPFE same MAP?
Dpfe
http://rockledge.home.comcast.net/~rockledge/RangerPictureGallery/DPFE_Images.html
Says it should be on the intake somewhere. I think it is the same as a map sensor, but I do not know. What year and engine is your car?
Dpfe
If that sensor is the same as your map sensor, it will not let it start.
Dpfe
Is your Fan / Fuel Pump relay control module bad? Passanger side strut tower, it looks like an ecu with a Connector with bolt on back of it. I think all those run through it to the ECU.
Dpfe
What engine is in the car?
Dpfe
Quote from: ACCEPT;373122
i can't found DPFE in my [SIZE="4"]3.8[/SIZE][/I][/B] cougar... it's DPFE same MAP?
:poke:
Dpfe
232' V6.
I' have 2 solenoid EGR
this is the DPFE
And this is the sensor solenoid.
now i' try to change the second...
Thank you for the answer
Dpfe
Quote from: ACCEPT;373228
232' V6.
Is this the original engine in this car?
Dpfe
Yes it is.
is a fabulous engine ... I remember that this engine shares a platform with a very rare model Jaguar MK-II 1960.
both cars the same number of cylinders and cubic inches
some degree of family may be...
ciao
Dpfe
What year is your car?
En que ano es tu choce ?
Dpfe
my car is a 1987 model sir.
Dpfe
Quote from: ACCEPT;372910
did not happen.
Code 31: EGR Valve position sensor signal too low.
Code 51: Engine coolent temperature shows -40°. This means the sensor is at maximum resistance or an open circuit. You would get this code if the connector on the sensor was unplugged or a wire broken.
Code 68: ITS (Idle Tracking Switch) failed in closed position.
Code 81: TAD(Thermactor Air Diverter) solenoid problem.
Code 82: TAB(Thermactor Air Bypass) solenoid problem.
Code 83: EGR(Exhaust Gas Recycle) control solenoid problem.
Code 89: Exhaust Heat Control solenoid problem.
Your car does not have a DPFE
