Topic: Dpfe (Read 6719 times) previous topic - next topic
Dpfe
What codes does the car pull?
Dpfe
Quote from: Haystack;373453
In post #1 ACCEPT posted his codes.
In post #15 I posted what they mean for an 87 CFI 3.8L engine.
Dpfe
Cougar LS 1987 3.8 VIN NUMBER : 1MEBM604XJH636073
The car pull this codes:
Code 31: Solenoid E.G.R. -
Code 51: Water Temperature Sensor (high signal) .-
Code 68: Air Temperature Sensor (low signal) .-
Code 81: Failure in the fan eletric .- (¿Radiator fan?)
Code 82: solenoid air bypass the catalytic converter is defective in the circuit .-
Code 83: Fan high (faults in the circuit) .-
Code 89: converter clutch solenoid .-
a test supply (EVP, TPS or MAP) and if they have 5 volt power
Dpfe
Quote from: ACCEPT;373481
Cougar LS 1987 3.8 VIN NUMBER : 1MEBM604X[SIZE="5"]J[/SIZE][/B]H636073
J= 1988 model year
Big engine difference between 1987 and 1988
87 is CFI
88 is SEFI
Dpfe
sorry... I thought that the fabrication date "11/87" and the model are the same.
I appreciate you clarify then
Dpfe
something that rolls off the production line that late in the year is 1 model year newer.. for example, 1 year later in 11/88, the MN-12 birds/cougars were in production, which is the 89 model year
Dpfe
The EGR sistem is new for my... may be this codes are common mistakes.
Code 81: TAD(Thermactor Air Diverter) solenoid problem.
Código 82: TAB (Termactor el escape de aire) problema de solenoide.
Código 83: EGR (Exhaust Gas de reciclaje) problema de solenoide de control.
Dpfe
What steps have you taken from the efi no start link I gave you in post #2? This will tell you everything you need to do to make it run.
Dpfe
Post#2 gives you a way to fix all of your problems. Joel5.0 also is from porterico so if you have a question, he might be able to help. You better.
Dpfe
Reply #39
thank for your help
then
the first step is check the 51 and 68 codes
the second step is check the 82, 83 and 89 codes.
Cat news later
Dpfe
Reply #40
Quote from: softtouch;373484
J= 1988 model year
87 is CFI
88 is SEFI
I made a stupid, buy a 1987 ecu for my cougar 1988.
That is the problem codes
thank my brothers.
Dpfe
Reply #41
Your car is running now? Wrong ecm?
Dpfe
Reply #42
not yet...
maybe in 2 week more comes to my home the ecu i bought for ebay, not so expensive only $ 20 US.
any of you need a 87 ecu?
thanks
Dpfe
Reply #43
J= 1988 model year
87 is CFI
88 is SEFI
Actually the '88 is EFI it's batch fire, not a sequential system...
Although it won't be correct by any means, I'd think it would at least start on the '87 ECM... I know someone whose ECM burned up(literally) in a '93 F-150 Lightning, to be able move the truck a 6cyl ECM was tried and it did run...
Dpfe
Reply #44
Anyone have any pin outs for the 87 and 88 ecu's? As long as the tps and igniton wires are right it should start on staring fluid. I could see it not firing the injectors long enough to keep it running.
