Topic: Aod swap (Read 5840 times) previous topic - next topic
Aod swap
I just separated the AOD from the 3.8 to use with my 5.0. Is the converter usable? or do I need one for a 5.0 .
I also have a flywheel from my C6 that bolts to a 5.0 and matches up to the flywheel of the 3.8. ( except for the motor bolt holes) Is this usable with my AOD? If not, what do I need to use my 3.8 AOD with my new 5.0?
Aod swap
You need the trans. I have. Not sure about the FW, but I have one from mine if you need it.
Aod swap
That trans won't last too long behind your combo jerry.
One out of an sc would be a better bet.
The convertor will be too tight as well,you'll want something more in the 2400-3000 range.
Aod swap
Well my GT40 5.0 blew up a stock V8 AOD. If you're using GT40 heads/intake on your car there is a good chance you'll kill the V6 AOD faster than I killed my V8 AOD :hick:
Aod swap
Quote from: dominator;314907
The V6 converter is actually SLIGHTLY looser than the stock 5.0 converter from what I understand, but it aint gonna be near enough.
Aod swap
Quote from: V8Demon;314935
yes the V6 converter has a higher stall, I'm not sure how much, but behind a 5.o ho I noticed the difference when I went from a V6 converter to a V8 converter.
The Converter out of a Mark VII has the highest stall out of them all.
FORD The Pacemaker of a CHEVY
Aod swap
You still need mine, I guess nobody got the answer you asked, I'm not sure. Do the teeth line up, same amount?, and all the holes line up?
Aod swap
Quote from: Kitz Kat;314954
You still have to check the balance weight.....
Aod swap
Quote from: V8Demon;314958
I thought of that to, but it came from a 302, I didn't want to confuse him more. Maybe I should.
Aod swap
Bye the way not many C6's were bolted to 302's. Maybe you should use it? With that big shifter, You may have to redo that console though! lol.
Aod swap
would it make sense to use the C6 for now? It seems to be the consensus that I will kill the 3.8 aod.
I'm not even planning on cruising the 87, now that I got the vert for that. the 87 will be possibly show only, and probably a couple runs at the track. (maybe) if I even let it out of the garage. lol
The speed limit on this island is only 45, and I don't plan on leaving it with the 87 unless its on a trailer anyway.
Aod swap
That c6 is a tough trans, and it will break the speed limit.
But you still need mine for originality.lol, I think I just unsold a tranny.
Aod swap
ok, let's hear it.....Aod from a 3.8, or C6? I'll need something, and I already have both, including the shortened DS for the C6, and mount for it.
This doesn't have to be permanent setup for the car, but with all the rebuilding and upgrades, another Aod is going to cost more then I want to spend this year with a motor rebuild happening.
Aod swap
What can I say. Go for it!!
Aod swap
Still say for the money it is going to cost you to get a custom driveshaft for the c6 and loosing od, you should try to find an aod out of a supercoupe.
They were the strongest of the aod's and handled 300+lbs feet of torque out of the box.
Go on sccoa and put up a wanted add in your area,you'll definetley find one for cheap and it will bolt right up.
