Topic: Aod swap (Read 5787 times) previous topic - next topic
Aod swap
PM sent back John
Aod swap
looks like I might have solved my AOD problem....
more later
Aod swap
Where we at with this Jerry?
Aod swap
How many miles is on the 3.8L AOD?  I have a 100K mile 3.8L AOD behind my slightly built 5.0 HO. It has a Transgo and I don't use OD, except for the highway.  It's still alive, but I don't beat on it to often.  The AODs are not as weak as people say, especially if you put a shift kit in them, and no WOTs into OD.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Aod swap
Sorry, I forgot to update.
I found 1990 SC Cougar AOD, and possibly the entire car minus motor and front seats. Anyone need parts? I could possibly get the entire thing, and part it if there's a need for parts here.
As for the 3.8 AOD.. I got 110k on it, and my motor build will more then likely smoke it within a month.
