Topic: I really HATE the 2.3 !! (Read 31947 times) previous topic - next topic
Reply #195
So the argument is which engine sucks more while sucking less?
Reply #196
Quote from: stuntmannick;201160
Since the 2.3T isn't running on vacuum under load, I'd say it's the 5.0L that's sucks more. :hick:
Reply #197
Quote from: oldraven;201172
 And that's a hard one to argue with...
Reply #198
The 2.3 swallows a lot for it's size though:hick:
Reply #199
Well at least BOTH swallow and neither....uh nevermind lets not go there :giggle:
Reply #200
Quote from: V8Demon;201199
Then shiznits it self.
First and last post on this one.
Reply #201
No cuddling afterwards!
Reply #202
Quote from: V8Demon;201225
You gotta cuddle with the 2.3L, we all know how they don't like to be shut off hot.
Reply #203
That's different.....If you shut me off while I'm hot certain parts turn blue.
Reply #204
5.0's more fun... Or so I'll say only owning two v-8's and two v-6 cougars thus far...
However, I am building my new tbird motor as a 5.0, not the v-6.
Really I guess I just wanted to say that the v-6 sucks.
Reply #205
Quote from: V8Demon;201238
You're lucky you're not a 2.3T, and those 'certain parts' don't crack. :eek:
Reply #206
So this thread is still running ?
Oh well to backup my original post, Aero, you are probably correct as I did a leak down test, 18% loss. Therefore 700 miles later I may or may not have broken rings. Unless of course they are not seated.
At any rate 2 TFI's later and 3 PIP's the car now runs all out with no issues in the upper gears...smooth boost all the way up to 22 PSI.
Guess it was an Ignition issue. (Motorcraft Parts were used, Echlin TFI worked, and the Motorcraft PIP)
I have connected 2 Valves to the IC pipes (BPV at the lower end and BOV right before the throttle body) This has almost completely stopped the Trailer Hitching I experianced when I let of the throttle.
So now I will beat the living  out of it till it piss's me off again, and see if the rings seat. Or blow it up whichever comes first.
Then I will drop in the 165,000 mile bottom end in and see how long that lasts.
Then I will go V8, maybe something big, I havent decided yet....Hmmmmm
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
Reply #207
They seated, then broke. It's the tenth or so one I've heard about in the last 2 years (and at least 7, including my engine, were confirmed). I honestly think they're might be a manufacturing problem. What brand/part # rings are they?
Beat on it, but it's going to blow oil everywhere like the Valdez.
Reply #208
The rings are Perfect Circle, of which I believe are made by Mahle.
Yeah it is blowing oil all over, I am rigging up a pcv from under the lower intake to run into a catch can and then into the front of the turbo. Blocking off the port in the upper. for now.
 thing leaving oil stains everywhere.........
1985 Thunderbird TC
Reply #209
Grab the Summit branded catch can. I ran a hose from the valve cover (aftermarket Esslinger one, it had no breather hole but a tapped hole in front) to the can and one from the PVC to the can (blocked off the intake fitting).
Perfect Circle's are made by Mahle, and that's what I used as well (Mahle bearings too).
