Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1530074 times) previous topic - next topic
Reply #585
You know you can barely see where you welded the 1/4 on, but I felt it!! it's good.
Reply #586
Sweet work.I had those cap strips off of the blue car.It took me a little while to figure that out.I thought they were stuck on.I wish they were.
Reply #587
Quote from: Kitz Kat;244586
It looks a lot better without all the colors around the seam high lighting it. It's hardly noticable when you run your hand over it after I stripped all the coats of paint off. I'll probably only need a quart of filler on the entire car.
So the plan is.. To strip the entire car, do my filling, then epoxy all the body panels. Then I'll start blocking the car flat and smooth.
I'm also going to finish the blasting from back to front, replacing and repairing whatever I find along the way. This should keep me out of trouble for the winter.
Reply #588
So I decided to keep on stripping the car, and this is what I found.
hmmmmmmm.....
So I thought it was just a small bit of filling around the handle......
Guessing the doors were stripped, skimmed, and blocked at one point.
I thought The doors had a little wave to them in the shop lights. And also sounded a little dead when I tapped on them.
The big question now, is leave it, or strip it bare again.
Checked the other door to make sure it wasn't just on one door.
Reply #589
My doors were like that as well when I was sanding them.I'm guessing that was from the factory.You're really doing great.For a while,it started feeling like a dreaded job-now I'm excited and enjoying every minute of it.I think after nearly two years,I was getting a little burnt out.I have my second wind.I'm working on the Sport tomorrow.It should be ready by tomorrow after lunch,before supper.Now,I need $200.00 more for the paint job.I had to spend a little of the paint funds.No big deal.I'll sell some more parts and my Cobra Mustang computer (which will bring a few bucks I hope).As far as filler,I don't think I used but about half a quart on the car,if that.I didn't have a bunch of welded panels either,though.Keep it up Jeddy.
Reply #590
Oh shiznit man that's not a good surprise :( ..  I would strip it.. see how bad it is and maybe find another door.. You've been doing such a good job with this, i doubt you'd feel right having so much filler on your car that you didn't put there.
Reply #591
and on top of that, how old is the filler already?  older filler will be destined to crack before the rest of the car is ready to be put down.
1987 TC
Reply #592
I know the doors were in storage for about 6 years
Reply #593
What about Vinnie's comment, that the filler may be from the factory? Either way, I think you're doing the right thing by stripping the doors. You need to have them bare and see what you're up against.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
Reply #594
I can't see ford going through all that on a set of doors unless they got damaged after they left the factory. there's small spots of dark gray primer under the fill. they were definitely stripped and redone at some point. there are no dents or creases looking on the inside of the panel. they were also undercoated inside the doors
Either way, it's got to go.
Reply #595
I'm definitely going to strip it down to bare metal.
As far as I know, there may not be any filling except for that handle area. The yellow, I was told is probably Dupont URO prime. A high build primer/filler. So It's out of here, and I'll cross my fingers that the doors are OK. I should be able to attack that this weekend to find out.
Just thought I would update my plans for the doors.
Reply #596
As I stated,both of my replacement doors were the same way.They were original paint.......for now.
Reply #597
Quote from: vinnietbird;244902
Let's see...
I thought mine had original paint too.
Reply #598
Iv'e seen that yellow coating on a few 80's ford panels, I'm pretty sure thats a factory thing. If its only a little putty may of been damaged in delivery or on the lot, seen that a few times.
Reply #599
my 88 linc had that as well on some panels
