Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1529737 times) previous topic - next topic
Reply #570
, looks like I need another pass
Reply #571
Oh well,you have plenty of time.The masks are going out Monday.I have been so distracted by body work (I'm actually enjoying it) that I forgot to mail them,and 4 Ebay packages.I hope I don't get negative feedback from those folks.Good work on the Cat so far.
Reply #572
Yea I know, I have all winter.
BUT, It would be great to have the bodywork done, and everything ready to paint come early spring.
This part, up in and around the trunk well, is probably the worst and hardest part to get to. Lots of small spaces.
Thanks for the masks, I'll look for there arrival around the holiday
Reply #573
Eh its not a problem
I figured id offer to you, other wise its gonna go in my new mark with a bigger pump
Reply #574
So I blasted for a better part of the day. I and it just isn't looking any better. Most of the areas, I can't get close enough to get the rust off. and the rest, It just won't come off any more then it already has.
Looks like I'm gonna have to convert the rest of the rust, and seal it with rust coating.
Here's what I ended up with.
And for those of you who require a little progress in their pics.............
Reply #575
yea looks alot like what i did with the vert it is hard to get i some areas...so thats what i did was use aspho to netrulize the rust i then coated it with pour 15  and then i rino lined every thing...turned out great
Reply #576
Hmm.. that's a lot of exposed metal, hopefully you coated it :D
Reply #577
Quote from: baxo;244342
Coated it?
LOL
Reply #578
I use the 3m (chemical / biological) filters on my mask.  Im not sure why everyone siad the 3m masks were not good enough, i have lots of sealed filters that you screw on each side of the mask.  Maybe you guys thought I was talking about dust masks.  I like this kind of work you doing.  The blasting part is where all the good detailed quality comes in so the primer has its fullest effect.
thanks for the latest porn,, :D
Reply #579
I use the same filtered masks for the bad stuff, and the lighter duty face masks for the body work.
That rust treatment paint (zero rust in my case) will grab onto just about anything that doesn't flake off. I treated everything yesterday with picklex. Bare metal and anything that still has some surface rust.
That quarter panel will stay looking like that for a long time without rusting. (about a year) I just need to scuff it before I prime it or do filling.
Reply #580
That Picklex stuff is good, I just google'd it.
Never knew it was enviro friendly although you probably said so somewhere.
cost?
found at?
Reply #581
Quote from: jcassity;244517
cost?
found at?
Here's where I usually buy most of my stuff. Sometimes I can find better deals elsewhere, but this is almost always the cheapest place.
I also belong to this forum too. As they say, it's my home away from home. I always double check with the collision pros before I rip into anything. ;)
Picklex is very good and safe to use. It's a little pricey at $32 a pint, but I just started using my 2nd pint the other day on the body panels. A couple small spritz's and a scuff pad did the entire quarter. Just work it in, and wipe the extra residue off with a paper towel. One pint would probably do a normal job though
http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RCAC
It will convert rust, and keep bare metal from flash rusting from moisture in the air. But it will rust if it's in contact with rain and snow.
Zero-Rust is on the same page. Definitely the cheapest place to find it to. I did find it cheaper by $2 once, but that place is gone now. But $52 for a gallon of black is well worth what the product does. Right now I have used just under 2 quarts on my car. It's sprayable, brushable, and paint roller friendly. doesn't need to be activated and doesn't stink to high hell.
Reply #582
Yeah I mean that all looks good really. All the loose  is gone...looks good and solid anyway...I mean if blasting wont rip it off...lol aint goin anywhere so that encapsulator stuff oughta be great.
And that shot of the back corner looks nice...mmm fresh steel :cool:
Reply #583
wanna fix my car? I need a plate for my upper front bag mount... its rusted out
Reply #584
Quote from: daboss351;244565
Sorry, there's already someone in front of you. :D
A little progress today.
Things are still moving along
and just in case you were wondering how those silly cap strips came off.
