Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1529623 times) previous topic - next topic
Reply #465
Vinnie, if you buy tools from there, you have to take them out of the box and use them. LOL
Today is another day to move things along.
Like I said, I need to seam seal where my hand won't reach.
Here are some pics of the backing strip being welded on.
Next is to fit the 1/4 panel and check the alignment.
When everything looks good. It'll get welded.
Until next time.
Reply #466
I have to use the tools if I buy them?  !!!!!......That ruins everything. I STILL have to use the air tools and compressor I bought in June of '07 (still in the boxes). I haven't even removed the door panels and window trim I got from you from their boxes yet. I figure they'll be safer there until paint.
Reply #467
Quote from: vinnietbird;240462
I get the impression that everything in your house is still in it's original packaging. LOL
Do you have plastic on your sofa?
Reply #468
Nope,everything in the house is actually used.LOL.In the garage,that's a different story.I'll get the compressor out soon.I need to replace my strut bushings.I haven't even see the compressor yet,just the big box that it's in.LOL.
Reply #469
So I got things ready today, ground down some welds, and did some behind the scenes sorta stuff inside the wheel well for welding.
Here's the panel for it's last test run.
I had it on and off about 5 times, grinding and fitting the panel.
Mabe 1 or 2 times after this pic.
the back end is even.
Well, it's official. It's now part of the car.
Here it is tacked on.
I can actually say that I put the car back together in less then a year. Feels good to get that out of the way.
It still needs to be welded, inside and out. But I won't be tripping over that thing anymore. LOL  It takes up a lot of space.
Another thing to remember when welding.....
don't drop your gauges on the floor when swapping gas cylinders.
These are usually at 0 when not connected. oops... I wanted a nicer set anyway.
That's all today  :D .....................
Reply #470
And for those who didn't see my video rebuild tour.....
http://www.foxtbirdcougarforums.com/showthread.php?t=21417
Reply #471
Seen the last pic, been there sucks. The stripe lines up better though!!
Reply #472
More stuff,
Got these parts for my car, when I met up with baxo and dominator.
Had a great time that day. We'll have to do that again.
Reply #473
That sucks .... (your gauges).....but yeah definately  time for some new ones! The car is looking good ...any special plans for the motor..
[/IMG]
Just enjoyin the ride!!!!
Reply #474
Quote from: massCougarxr7;240730
Nothing special this time around, just a stock 302 HO.
Reply #475
moving right along.............
I welded the panel on today.
But wait, there's more
I also finished more doors for my house today too. I'm up past 100 so far. :hick:
and base board
Here's a shot of the size difference in panels between the cougar and bird.
The lips, and some other frustrating areas are not the same.
I also believe that the quarter panel has a different shape to it past the wheel well.
here's the inside view.
Everything ground down and pretty looking
A little welding and grinding in the door jamb.
Here's how the door lines up after everything is together.
just needs a little adjustment now.
So talking with my neighbor, and looking at my frame in the front of the car, he says that It can just be fixed, and made stronger then the original frame. Come to find out that he also used to add reinforcing to dump truck frames for a company, on top of repairing them. No worries now. My car will be built like a dump truck. LOL
That's all for today. Until next time......
Reply #476
Hmm I would have thought that the quarters were the same except for the original parts that you left on the car. Do you think that they could have warped after they were removed?
Reply #477
Quote from: thunderjet302;240764
There really wasn't anything that would make them warp. I used the nippers that cut out the center piece.
the other side was the same way along the vertical seam and didn't quite match along the lower joint under the moulding. I can only assume a difference in panel shape right now. but remember, the trunk lid on a bird is tapered  in width from window to latch. Cougars are straight. I'm guessing the quarter must have a bit more taper to it too.
Reply #478
Hey, I'll vouch for the quarters. They may have warped somehow after they were removed, but I know they were taken off with loving care! :D
1987 Turbo Coupe - Son's car
1934 Ford - My project car
Reply #479
You did a great job with the quarters Mike, There's no way they warped the way that they're out of whack.
I think I know what the problem is now.
The inside welding s of my cougar, and the s of the bird couldn't be totally separated from their original welds. They seem to be rotary welded around the entire , so the end result is 2 extra thicknesses of 20 ga. sheet metal sandwiched in between my wheel well. (Approx. .0718" ) and with any gaps between the 2 different panels, I can see where I could gain an adittional 1/8 that the panel is off.
Problem solved.
long story short......It just needs a little filler. LOL
