Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1531714 times) previous topic - next topic
Reply #240
I would love to see this car when it is finished.............CJ2009?
Reply #241
thanks!!
Reply #242
Truely incredible daminc...!!!
I think I should take a welding course this summer or something.... you've definitly inspired at least a few of us!!
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
Reply #243
I wonder if yours will be done for catjam, and if mine will be done...
Reply #244
Mine may be done for Catjam 09.
after I rebuild the car. I still need to rebuild the motor.
Need another rear end. and I'll probably do the 5 lug swap.
I have been accumulating parts for the full console swap, full digital cluster, full lighting package, and possibly a roll bar in the works.
Then the body work needs to be done and paint. and finally the car needs to be put back together. did I mention the 5.0 upgrade.
I'm sure there will be something else going in the car. but thats kind of a rough sketch of everything
I guess I have a bit of work ahead of me.
most of the mechanical stuff I'll have a hand with. should speed things up a bit.
Reply #245
Hey, Jerry have you started a (scratch/check) off list in the Garage Yet? :popcorn:
Reply #246
This is the last of the drivers side rebuild.
I finished up the welding and put the last piece on the rocker panel.
Put a coat of Zero rust on everything and will finish the rest of the seam sealing and 2nd coat during the week.
I had to do a little aligning to finish the rocker bottom and weld it to the quarter panel
Here's the last piece of the side being bent
I'm going to miss those magnets one day
I did some, "just in case" welding.
Did a quick patch in the back
Started to coat a few things.
I'll put Pickelx on all the bare metal to keep it from rusting.
seal and coat everything again then on to the other side of the car.
Reply #247
Yesterday, I've been part of the group here for one year. In that time, I've learned more than I could have imagined about our cars. I've met a lot of good friends also, in that time.
So I just wanted to say, thanks for all the help to get my car this far. I couldn't have done it without the support of everyone, and of course the parts that everyone has helped to get for me.
Thanks,
Jerry
PS..... The project has evolved from the flintstone project as of now.
Reply #248
Today I seam sealed the rest of the drivers side.
I'll paint it again with encapsulator, so I can try to get the car turned around for this weekend.
I used 5 tubes of seam sealer on this side of the car so far.
I worked about 8 hrs last weekend and today to get things finished up.
This coming long weekend.
SIDE 2 coming up
Reply #249
When you get it road worthy, I know the perfect vanity plate for it:
PRIDE
It is rare these days to see someone who takes this kind of pride in their work and it is  good to see. Most would have sped it as too far gone. I'm glad you didn't. This will be a project you can be proud of. "See this car? This is what it looked like when I started. Yeah, I did that."
I can't wait til you can bring it to Catjam and really show it off.
Reply #250
A bird that rises from the ashes is called a phoenix. What would you call a cat that rises from a pile of rust?
Reply #251
Quote from: Thunder Chicken;219947
I've been searching for the right name for a while now.
It's not Flintstone like anymore. (although I was talking to someone recently who may have the next flinstone project.)
It has certainly evolved from the "rust with wheels under it" look.
I researched cougars again last night, and found a "Cougar Spirit" from Native American folklore. Doesn't really have anything to do with this situation, but it was good reading if anyone was interested.
A new name will come when I least expect it. It always does.
Reply #252
This side is officially done and ready for bodywork.
[SIZE="7"]NEXT!!![/SIZE]
Reply #253
AMAZING! that is the only word for that picture. hats off to you
Reply #254
good work man!
