Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1531747 times) previous topic - next topic
Reply #270
It's an 03 and there's already rust around the windows.
Reply #271
yep
chebby products..... I swear there WAS a 03 chevy van around here
body was in worse shape then your cougar
floors and frame rails rotted right out of the  thing
it was horrible cause it was newer.
Reply #272
The only reason we still have it is, well, it's pretty quick
Reply #273
Now that I'm advancing beyond lurker status...I just wanted to say: WOW!  The work that you have done for this car is beyond awesome.  Like others have mentioned, up until now, this level of work has been unheard of for fox cougars.
I'm going to need to take some welding lessons myself; I've got a lot of rot in my car, as well as a few plugged holes (from the antennae and lightbar).
-Rob
1996 Police Interceptor- 173K miles
Engine: '03 SOHC 4.6, Underdrives, FRPP shorties, 80mm MAF, Watson Engineering downpipes, and 70MM T/B. Oh yeah, Dyno Tune done by Livernois Motorsports.  :evilgrin:
Tranny: '00 4R70W w/ mild J-Mod +  Spiral Lock clip, 11.25" torque converter, and an auxillary tranny cooler.
Reply #274
So after it's all done are you going to run around with a 5.0 HO and wire wheels? It would be funny to see you burn the tires if you keep the wire hubcaps :D
Reply #275
Quote from: thunderjet302;222510
LOL
I may even keep the whitewalls. Who would expect a HO in it. :evilgrin:
Reply #276
Quote from: theredlineboss;222473
-Rob
It's just a Mustang thats a little longer. I never thought it was odd to want to rebuild it. I thought everyone else on the board was doing stuff like this when I joined. I didn't know you could still buy one in one piece out west. :hick:
Reply #277
Quote from: daminc;222525
and ALOT less power...
Reply #278
Jerry, count me in as one of those "everyone" guys,lol.  You'll be finished before me, though.
1987 TC
Reply #279
Quote from: HAVI;222629
We'll see what you think after you see this side of the car. LOL
Scott, I have some side moulding you can have. (front Quarter panel moulding)
Well, Its time to get the other side going.
I got it back up to work on this side.
Now it's time to look over the damage.
The rocker on this side is in pretty good shape. The front part is un-rusted as is the rest of the panel until it gets to the quarter panel seam.
The bottom seems a little thin, and I'll probably cut it out and replace the flat section that gets welded to the floor pan underneath
Looking at this side, I see that it's a lot better then the other side.
Here's a pic of the condition of the rubber on the windows of the car. I hear a lot of talk about everyone needing new 1/4 windows and dew strips. Its about the only thing I don't need on the exterior of my car.
This side will get the same treatment as the other. Just a bit less in the panel replacing.
The quarter panel will get cut, much like the other side.
I'm still undecided about where I'm going to cut the panel where it meets the door
The inside jamb and the rocker will get replaced like the other side
Well, thats all I got to show. Now it's time to do it.
Until next Time.
Reply #280
god nn
Reply #281
In light of post #280, it'll be close, lol.
1987 TC
Reply #282
That was a lot of rust but Great work so far man.
Reply #283
I started the pass. side this afternoon.
I cut out the bad spots
You can see, the rocker front doesn't need to be repaired on this side. I pulled the plug out and stuck my finger in there. I didn't feel any rust at all inside there.
Started pre-bending everything, so I could weld it up at one time
another gorgeous day in Buffalo, NY
Here's a little more pre-fab work. Everything marked
And as they say on the cooking show,  BAM!!!
(You gotta have the lines in the floor.)
On to the back.
I'm skipping some pics, because it's mainly a replay of the other side. there's also less to repair, as you can see by the way it's moving along.
This all happened in about 2 hrs. time
Here is the back of the pan cut out, like the other side.
here is everything ready to be welded. just need a few more pieces to finish it up.
I'll also fill the hole from the plug. It's easier to cut the floor for the frame, when it's solid.
Of course, everything will be treated with pickelx, before welding.
I'll open up the frame to treat the inside of them too.
(I feel like I've done this before)
Thats all for today my friends.
Reply #284
Your Monte Carlo has a 100000 mile warranty against rust.
