Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1535958 times) previous topic - next topic
Reply #1350
Todays work,
And a couple random pics of the car.
Reply #1351
Nice. I would like to see how all the sound deadener stuff works out for you.
Reply #1352
It seems to be pretty dead sounding when I rap on the underside of the floor.
the first layer is butyl. 2nd is rubberized/asphalt  layer (basically torch down roofing).
3rd layer is the aluminum insulation/ radiant barrier. it also has an R-13 insulation value.
The padding under the carpet will be the 4th layer in the entire mix, follower by the carpet.
Reply #1353
Quote from: daminc;273593
Leave some room for the gas pedal to move. I have a hard time shifting mine with the floor mat in.
Reply #1354
Quote from: Kitz Kat;273647
Not a problem. With everything I'm putting in, it's still thinner then the original sound deadener that a sed out.
Reply #1355
Same here.
Reply #1356
So whats the cost of the supplies to make your sound deadener/ insulation?
Right now my car has front seats, seat belts, dash, and a dome light. Everything else is out to be cleaned and fit my floor rust.
Im know you said in here someplace where to get the POR-15 but I can never find what Im looking for. Where should I get it from and how much will it take to do the floors, and what all would I need to do your insulation method?
Reply #1357
I would have to price out what I used. Unfortunately  I buy in bulk for a job, which means you would probably pay more then just buying dynamat, and would have a load left over for the small amount that you would need for your car compared to what you would buy. I figure what I'm putting into the car would be around the $250-$300 range. Mabe more because I'm also doing all the interior quarter panels, trunk, door,and probably the roof.
I guess My actual cost to to this is $0, because it's left over
The zero-rust you can score here. it's about $19 a quart and $60 a gallon.
if your just doing the inside floor, you will only need a quart. if your doing the underside too. I would just get a gallon for the $60. Just brush and roll it with a small 3" roller.
they also have the pickelx here to if you want to convert the rust as a 1st step.
http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=6RCC
Reply #1358
So Zero-Rust not POR-15, and the pickelx should be done to do it right huh? Think Ill go a gallon since Ill probably end up doing the underside where the undercoating has come off and rust is starting. Trunk wouldnt hurt either.
Did you have any rust on the inside of  the roof? I have some at the front center an on one of the sides. Thought it was a little odd.
Thanks
Reply #1359
I haven't taken the head liner out, so I  don't know if there's any rust up there. I hope not.
Reply #1360
Today was a good day.
I finished up the floor today
and dug out some goodies. It feels like Christmas today
And just to be ready I pulled these out too
So I did a little dry fitting
And like someone read my mind, and drew this up just for me. I went to work
And finished up the floor
And then it was time........................
I still need to cut the carpet and mount some things, but it's starting to not look so scary anymore
here's the back
That's all for today. ;)
Reply #1361
sweet. Its really starting to look like a car now.
Reply #1362
Nice man,gettin it done.
Either picklex or por-15 will work.
Jerry uses pickelx i use por-15,they both work very well.
I have personal experience with por and it works very very well,at least it has on my sc over the winter(no rust).
I also put some on a buddy at works 89 z24 that is all rotted out and the rust never came through even with all the salt up here and that thing is rotten,probably worse than jerry's ride although.......lol.
Reply #1363
Wow nice work! Although I would have thought you'd paint it black inside there before you started putting the interior back in, or at least paint the door jambs.
Reply #1364
The painting has nothing to do with the interior. There's a greater chance of me scratching something putting the interior back in. Those seats are pretty heavy with the motors. This way it's pretty much all set after the painting. It'll all get covered and sealed up whether the interior is in or not.
