Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1536581 times) previous topic - next topic
Reply #1125
OK, it looked lighter than Eastwood's red.  Maybe it's the lighting as well.
1987 TC
Reply #1126
It is just insane what you are capable of doing.
are you going to be spraying the car yourself, or have it done?
Reply #1127
I'll be painting it myself
Reply #1128
I'm just in awe. Wow.
Reply #1129
I was actually going to ask you if you were going to do it,,, but you did in post 1122!!!!
That will be the best thing you ever did.  That galley in there holds a lot of  and promotes corrosion.  My 3.8 headlamp harness ran under my battery in that area and a leaky battery didnt do good things to the wiring under the battery.
scott
Reply #1130
Quote from: jcassity;264699
scott
The front part of the frame didn't have much rust on the top. I used to vacuum it out all the time when I would clean the car. Isn't that the silliest thing you ever heard? :rollin:
Reply #1131
No it's not, because I do the exact same thing!!!!! And if I can't, I get out the air compressor and use that to blast out all the ! :rollin:
Reply #1132
I have a hole in that area,, often wondered how fruitless my trying to fix it would be when knowing all too well that the corrosion is up in the tunnel and i couldnt get to it unless i cut the top out.
Reply #1133
Quote from: jcassity;264954
Well, when you get it into the garage. I'm sure it will be on the "To Do" list
Reply #1134
Up to 57 pages for me... now I'm caught up. :D
:jerry::jerry::jerry:
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
Reply #1135
Wow great work:D
Wanna come over and fill all the holes in my engine bay? ;)
Reply #1136
Quote from: thunderjet302;265037
Wow great work:D
Send them to me. I'll fill them and send them back. :hick:
Reply #1137
Ok let me go pull them out and box 'em up :hick:
Reply #1138
:hick:  If they get here before Sat, I can get them sent back out by Monday. :hick:
Reply #1139
got a few pics today....
here's my in between project. I finished our media room yesterday
I may have gone overboard with the TV
Anyway here's this weeks update.
I started on the drivers side frame
I made some cuts and found a little rust
here's a little test fitting
and a little welding
that's it for today
