Topic: new cam, stall converter? (Read 3678 times) previous topic - next topic
im getting a cam with .542/.563 lift, 110 lope seperation 8 deg overlap advertised duration 224/232
what should i do for a stall converter? i have a 1988 AOD
Will a cam with that much lift work on a stock motor?
No.  What else is done to this vehicle?  E7 heads in stock form will probably not be able to reap the full benefits of that cam Let's not even talk about E6's.  Also you're gonna need a tailshaft governor that let's you go to around 6000 RPM.  I'm guessing you have a 7.5" rearend.  I'd recommend 3.45's, a 2800 lockup stall convertor and some decent heads with a mass air conversion as I can't see that cam making too much vacuum.
with a carb setup, your likely to have no real visible issues.
with an electronic setup,,,,,,,,,, your just asking to be kicked in the balls.  plain / simple ,,,,,,as already said,,,,, Vacuum with that much overlap will prob be the root of all your evil.
I have the same problem,,,,,,,, my cam is gonna bo bye bye.
so what is a good size cam then that i make make great torque and good horsepower?
B or E 303 FRPP cam is my guess.
i want to make more power then that though.
I honestly duno man. I think the heads are holding you back as much as the cam.
with the cam listed you need a 2,600-3,000 with a good steep gear in the rear end (4.10 or 4.56)
^ What Demon and Cass say
im looking at cylinder heads like these.
http://cgi.ebay.com/ebaymotors/ALUMINUM-SB-FORD-CYLINDER-HEADS-SBF-RACE-302-351W_W0QQitemZ330148602613QQihZ014QQcategoryZ33617QQrdZ1QQcmdZViewItem
im looking for a cam that will give me a really flat torque curve and also be heavy on the horses.
im getting a rebuilt HO motor in my car within the next couple of months, so im starting to buy stuff now for it.
how much power are you thinking your gonna get? your only gonna be in the low 300's
Quote from: quicksilver;162602
What rpm range are you looking at?
If you use that cam with those heads, watch for coil bind!
Yeah, I'm with Boss. Thats about all I'm shooting for with my car man
yeah, low 300's is what im looking for!! because acouple months after i get my motor, im going to turbocharge it. i want to run 8-9lbs boost.  im looking for 6000RPM.
