Topic: The "Stinkin Lincoln" is being striped!!! (Read 53253 times) previous topic - next topic
Reply #315
O yea next parts im saving for are custom subframe connectors by disneylincoln, and the fixed camber plates from chuck if he ends up making them! Should make the car handle alot better once I put those in, plus the turbo coupe sway bar in too.
Reply #316
just make your own connectors
Reply #317
200 bucks for a set of tig welded bolt up thick steel connectors isnt bad.
It all depends what else pops up on the car, and weather dis comes back on the site or not!
Reply #318
I've never priced them for my car, mabe I could have just bought some and saved some time
Reply #319
well this guy custom makes them for mark 7's he also sells custom twin turbo kits for mark 7's
Reply #320
Plus U would never find any as good as yours!! come cat jam if i havnt bought any, and if we meet up, maybe we can throw something under this pig! Id be glad to have a hand, and pay you for your help.
Reply #321
That would be a cruise.
Reply #322
brake lines are DONE!! Car mother ****ing stops!!! Bout  time!
Reply #323
woo hoo
today is marked as an official holiday
Reply #324
Now if i can get the idle down I can test drive it quick
Reply #325
My parts bird also runs like a wild rabbit. havn't had a chance to even look at it.
Reply #326
Got the idle down a bit and took it down the road and back!
Verdict is:
brakes need to be bled more
and i need the lers put on, neighbor hood came out to bitch and I booked it home! being 930 at night with a 2 1/2 inch h pipe and no cats isnt the best thing hahaha
Reply #327
lol, but I bet it felt good
Reply #328
Well  right it did!! Made all the hard work I put in worth it!
But it needs an alt.... I have always been charging the battery cause I forget to un hook it or something stupid, amp light came on after i drove it last night so its not charging I dont think. Perfect opportunity for a 3g upgrade!
Reply #329
3G is a good thing.I think the Mark VII uses a larger case alternator than the T-Bird/Stang 5.0.Check into that.
