Topic: Hmmm I wonder... (Read 25658 times) previous topic - next topic
Hmmm I wonder...
Reply #105
 what are you gonna do for a hood!
Hmmm I wonder...
Reply #106
trade with sleeper :hick:
Hmmm I wonder...
Reply #107
trade with sleeper
Yea Im gonna need a hood like that but I will be making one.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Hmmm I wonder...
Reply #108
i have an idea. you could put the blower where the turbo sat then move the turbo to where your stock ler is. so basically your turbo is your ler!!
Got that fox rash again!
-Resident smartass! :ies:
Hmmm I wonder...
Reply #109
Quote from: 88cat;156419
my hood is a one off VFN unit
Hmmm I wonder...
Reply #110
Quote from: Cougar8775;156452
Plumbing NIGTHMARE.
Hmmm I wonder...
Reply #111
Quote from: Ifixyawata;156475
Plumbing NIGTHMARE.
comin from you, that is freakin hilarious
:rollin:
Hmmm I wonder...
Reply #112
take a flat hood and cut out holes to let the pipes and filter hang out the top.....
Hmmm I wonder...
Reply #113
Here are some pics of the custom cowl hood I started to build today. The hood was from a 88 cougar and already had a hole from a previous 351w air cleaner. I also will be installing the turbocoupe scoops the cowl is 4.5 inches tall. Also you will be able to see a piece of the blower piping. Here are some pics
Hmmm I wonder...
Reply #114
Great Work! I don't know if you can do this due to opening the hood and movement but could you round the ends of the hole for the pipe?
Is it goin to be a lift off? Its goin to be a B as heavy as they are if it is.
Do you have solid Motor Mounts?
Hmmm I wonder...
Reply #115
Its not gonna be a lift off hood and I have stock motor mounts, but I made custom braces that go from the chassis to the engine and it does not move.
Hmmm I wonder...
Reply #116
Man, you must have a whole hell of a lot more money than I did when I was 16...of course I didn't have a car when I was 16 either. Or good garage access.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Hmmm I wonder...
Reply #117
Well im 19 and no dont have alot of money or a job at the moment I already finished my degree in automotive tech and no one is hiring sucks. Well back to working on the hood will post updates.
Hmmm I wonder...
Reply #118
Here are some more progress pics 2 more days and hopefully i will be done.
Hmmm I wonder...
Reply #119
Little update on the car well i connected the wg to stock setting and now im seeing 20psi but the bov is open always. Also In park i rev it not even hard and i see 10psi right away. I went for a cruise and did a 2 block burnout nonstop and could easily have gone more this thing pulls HARD. The boost now kicks in off ilde and the feeling is awsome for anyone who doubted that this was not gonna work shame on you. Will keep you posted.
