Topic: Hmmm I wonder... (Read 25767 times) previous topic - next topic
Hmmm I wonder...
Reply #135
What do you have the one idler below the supercharger bolted to? I can't even tell from the pics.
I also didn't know that super coupe superchargers had the outlet on the top and the inlet on the back :dunno:
I guess that probably makes them more adaptable.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Hmmm I wonder...
Reply #136
The idler right below the blower is on the alt top bolt and the idler below it is on the timing belt tensioner.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Hmmm I wonder...
Reply #137
where's the friggin vid?!
1979 Ford Fairmont
[/B]
Hmmm I wonder...
Reply #138
Im working on it.
Hmmm I wonder...
Reply #139
Well bad news I took the car out last night and it was running better than ever at 25psi if felt FAST. Today I was taking it out and saw smoke and smelled like antifreeze i checked where it was coming from and it was between my header and turbo. I picked my dipstick out while the engine running and oil started gushing out so im positive I blew a hg. I think im gonna might as well swap the engine now to the other one i have that looks to have a recent rebuild and give this old junkyard dog a rest and port my N/A head Im currently running. Also has anyone here tried the slider tc cam with ranger rolller followers did you notice a improvement ant bad outcomes? Well will keep you posted.
Hmmm I wonder...
Reply #140
Don't use the RR followers with a slider cam....
Invest in head studs.
Hmmm I wonder...
Reply #141
Im already running head studs.
Hmmm I wonder...
Reply #142
Quote from: 88cat;157375
i meant to ask what what kind of HG you were running. What were you running? and what do you plan to put in now?
Hmmm I wonder...
Reply #143
Hmmm I wonder...
Reply #144
I was running a felpro 8991 I beleive its the cheapest gasket felpro sells. And Im also kind of suprised how long it lasted and I had detonation you could hear a block away more than once and kept running. Im not sure yet what hg im gonna run.
Hmmm I wonder...
Reply #145
The 8991 is fine (or whatever the std Felpro turbo replacement is (8993 I think actually).  Unless you plan on triple-checking your head and block flatness for perfection, don't use the 1035.
Hmmm I wonder...
Reply #146
Yea I think its the 8993 the correct number. And i will probly use it again and just coat it again with permatex copper spray.
Hmmm I wonder...
Reply #147
Quote from: 88cat;157388
yup 8993
Hmmm I wonder...
Reply #148
Quote from: Chuck W;157385
What's wrong with the 1035? I have it on Layla and now you have me all jumpy...
Hmmm I wonder...
Reply #149
Quote from: Aerobird Motorsports;157437
also curious.
