Topic: Foxtbirdcougarforums Top 25 ET List! (Read 98355 times) previous topic - next topic
Reply #300
Nice, never got mine that fast on that combo
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #301
believe me it suprised me lol stock rear/gear an a big 850 double pumper swapped it over to a 650 for next time
Reply #302
I took the bird up to Lebanon Valley Dragway in NY on Saturday. Ran a best of 14.02@ 98mph. I was running 3.45 gears, 7.5 rear with trac lok, bald all season street tires, and about 7 pounds of boost on my stock SO motor with a Powerdyne blower. I have a TCI AOD with a 3000 stall converter. I had to launch very gently. Car has full interior, sub box, and trailer hitch.
A shot from the staging lanes:
Reply #303
A 2.0 60' is better than my best, which is 2.2, which sucks :hick:.
Reply #304
How do you launch and how were your tires? I'm surprised because I had to roll onto the throttle with my bald drift tires. I used my left foot to hold the brake while i tried to hold around 1300 rpm. Any more and it would get sideways and kill the times. The freshly rebuilt trac-lok must have helped. I have since bought a set of used drag radials on craigslist and am almost done converting from supercharged to a turbo. If its ready by saturday im gonna head back to the track. I really want those 13s!
Reply #305
One foot on the brake, one hovering over the gas, engine at idle. Third yellow comes on and I lift my left foot off the brake and slam my right foot to the floor. It usually results in wheel slippage/sideways action. This is on 225/55/16 Firestone Firehawks. I haven't run with the new heads yet (only with the GT40Ps) but I'm pretty sure they are going to make things worse. I'm hoping to get to the track next Friday night to find out :).
Reply #306
I used to use that same technique with similar results. You should try my new method. It seems to be working better.
Reply #307
Quote from: thunderjet302;396070
No, no, no, not even on drag radials...
Even on street tire I roll through the water, burn them to dry and roll SLOWLY to the line to cool the tires and pickup some traction compound... When staged, I hold brake, bring the revs to around 1200-1500, release the brake on last yellow and roll into the throttle... How quickly will determine on multiple factors, you'll have to learn your car...
Using the above, I've pulled best of 1.87 with the Marauder on the factory BFGs and 1.89 - 1.91 are easy...
Reply #309
Quote from: TurboCoupe50;396185
Thats pretty much how I was launching, but I drive around the water and skip the burnout when I'm on street tires.
Reply #310
Quote from: slowbird;396222
Spun bad on this run.. true street tire 255
 http://www.youtube.com/watch?v=zGtL-zh8tPE&feature=youtube_gdata_player
was this the run from the time slip you posted?
Reply #311
No my friends didn't get that run on tape I went 14.20 on that run spinning bad
Reply #312
Quote from: slowbird;394567
this was on motor
stock 302,shorties,explorer heads,e303 cam/C4 3500 stall nitrous convertor on 255 street tires
R/T.421
 60"1.907
 330"5.540
 1/8"8.550
 mph"81.59
 1000"11.175
 1/4"13.403
 mph"101.61
 New personal best 13.37@100 same set up as last time
Reply #313
Thats pretty quick on motor! I'm planning on going back next week. I put in a turbo and got some drag radials so i should hopefully be getting a new personal best too.
Reply #314
Ya I plan on spraying the car soon ... n putting the slicks on it.
Here the run broken down
Rt.  .120
60" 1.879
330" 5.496
1/8" 8.505
Mph"81.48
1000" 11.137
1/4" 13.379@100.80
