Topic: Foxtbirdcougarforums Top 25 ET List! (Read 98309 times) previous topic - next topic
Reply #330
No changes to the car? Probably making more power now that the weather is getting cooler. Nice run.
Reply #331
No changes. Weather was 75° really wanna get that 12.99 pass than ill start making BIG changes. Anyone think its possible the way it is to get that 12.99 pass?
Reply #332
Went to the track earlier again new pb:13.17@103
Reply #333
well just got around to posting about going to the fun ford weekend at pbir, I made it to the semi finals took 3rd place and got knocked out by a 2011 5.0 with a f1 blower that ran 9.50's (ouch) and it was heads up racing. This was the first time I ever raced other then test and tune, it was tons of fun. I was running drag radials and it was wicked hot so the best time I could turn was 11.6@117 a few times the smaller tires lowered my mph but I can say the drag radials brought the wheel up off the ground(got it on tape)
these are two inside the car runs sorry for the profanity in the second one I thought with the wheel spin off the line that car beat me but that was the 9.50 car, I was caught up in the moment.lol
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #334
saw this at the ford show
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #335
Quote from: slowbird;398813
You are getting very close. Is there any weight you can remove?
Reply #336
Not really there like the a/c stuff but its a street car so I don't wanna cut or remove anything car to clean/solid to do that ..
Reply #337
Here a break down of the run.
Rt: .112
60ft:1.873
330: 5.437
1/8th: 8.400
Mph:83.05
1000ft: 10.982
1/4: 13.177@103.15
I know for a fact if I stayed later I would've got that 12 second pass guess ill just try again next friday
Reply #339
Run 5w20 that will give u a little more rev, and make sure your timing us like 32-34*, and diet for 1 week
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #340
I run 5w20 timing not sure ill have to check it. Diet never was good at that lol.  Just really surprised how well it been running on motor wit a nitrous convertor. I would've never thought I would have this much fun going this slow lmao. I always seem to get a good laugh when people point or come up to me n say really why would u run this? They always come back after a run n say I surprised the hell out of them...
Reply #341
Bad day at the track,  started the day off over heating, plugs fouled, rpms wouldn't come up . Had to abort 5 of my 7 runs. Fuel tank has a bad leak according to track officials n something broke in rear I think, right tire is rubbing bad n clanking. :( just my luck. Best pass was 13.37@100
Reply #342
Nothing new guys? I only got a PB 60FT 1.84
Reply #343
Not gonna be anything new from me till spring. I got my new tranny in, but now the track is closed for the season :(
Reply #344
here is a pic of my 1st time slip getting in to the 10's with a 100 shot hitting it about 40' out(out side temp was in the upper 80's) i drove it 35 miles to the track and then stopped for icecream on the way home lol
  it's got a 347 mounted to a C4 with 4.10 gears in the rear and
