Topic: Foxtbirdcougarforums Top 25 ET List! (Read 98332 times) previous topic - next topic
Reply #315
Bryan163 keep us updated ... I always wanted to go turbo
Reply #316
Thats a pretty solid 60ft too. I'll let you know how it goes for me.
Reply #317
Quote from: bryan163;397266
Agreed what converter do you have???
Reply #318
^^^ I forget who makes it or if its a 8inch or??? But its stall to about 3k on motor should pick up alot more wit the juice n slicks
Reply #319
Its 7:30am and I'm about to start my drive up to the track in NY. Should have some new times later. Fingers crossed for some mid 13s and for the car to make it there and back in one piece.
Reply #320
Good luck, beat her down!!!
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #321
Quote from: 347thunder;397715
good luck, beat her down!!!
x2
Reply #324
Lebanon is kind off a slow track too from what the pros tell me. I didn't get to run because a rain storm came through. Gonna tryagain next week.
Reply #325
No new personal best for me. Went back to the track running 14psi and wiped out my tranny on the first pass. Gonna try to grab a new one asap before the end of the season.
Reply #326
Quote from: bryan163;398497
How did it die? No gears or blown inner input shaft?
Reply #327
It still works, but won't shift under very heavy acceleration. It also shutters sometimes when taking off from a stop. It was a TCI Streetfighter Trans and converter. Gonna try a different Trans builder this time. The new tranny im getting is rated for 700HP with a 2 year warranty. Not sure if I should spend the extra and replace the converter as well.
Reply #328
Quote from: bryan163;398588
I would get a new converter. The old one is probably full of junk from the now dead AOD.
Reply #329
NEW PERSONAL BEST...
Same set up on street tires
Rt:.135
60ft:1.882
330: 5.456
1/8: 8.427
Mph:82.45
1000: 11.027
1/4: 13.23@102
