Topic: 5.8 Fastcat #2 Winter Work (Read 43741 times) previous topic - next topic
Reply #135
O.K.,I'll get a set of the pipes.Now,if they don't work,you'll refund my money,riiiiiiiight??? LOL!!!
Reply #136
So long as you are willing to cut and weld a bit :P
(edit: the rear hangars on Mustang tailpipes don't work so you have to cut them off and weld tabs onto the tips to hang the tailpipes)
Reply #137
Nice airbags in the back! Who are they made by?
So you have a V8.......isn't that cute.
Reply #138
http://www.foxtbirdcougarforums.com/showthread.php?t=11024&page=13
Reply #139
Greg, I've been watching this thread with alot of interest, and I gotta say the car is lookin great! :bowdown: I've been in the planning stages for this spring to do some rotissere work myself, but I have a question. Was there any concerns/problems/issues with leaving the front and rear windows on the car?
I didn't want to remove the windows, but was concerned there might be issues with the windows either poppping out, cracking, or seals pulling apart that could cause leaking. I will be welding in subframe connectors before turning the chassis to minimize twisting though.
What are your thoughts?
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Reply #140
I would weld the subframe connectors 1st. I left the frt and rear glass in my car. I also left the doors on while it was on the rotessier.
  Hope this helps.:D
Reply #141
Fastcat with your 351 what afr heads did you use? When i build my 351 up i wanted a set, not sure which ones will give the best performance for street strip use. Not gonna turbo/supercharge mine though, i just want a bad ass small block chevy killer. And i can't wait to see that thing done man tis gonna be sweet!
Reply #142
I used the AFR205 heads. If I was going to build a naturally asprited 351 I would use the 185's. The  205's would kill the low end without a poweradder.
  Thanks, Trying to get the dash and interior back in.  I'll post pic when I get some more done.
Reply #143
thanks I apreciate that, yea i want to be able to run it all N/A so i can have a small block from hell, 408w stroker
Reply #144
408's are block eaters.  The rod ratio makes them relly hard on the blocks. Short life. Go with a 393 or a 383 windsor. Just my 2 cents
Reply #145
15ci makes that big of difference? i thought i was playing it safe staying away from a 427w stroker, i heard they could be stroked out that much. i guess ill do a 393 then. How much power do you think it would push with just being stroked, and the mods in my sig?
Reply #146
Carb and T5 car whould make around 360-380 RWHP with a streetable 9.5-10.0 comp.
Reply #147
THATS IT! wow im disappointed i was told i should be high 300's right now.
Reply #148
LOL!! You're not even close! I'd guess somewhere between 280-320 rwhp depending on cam. 700cfm isn't flowing that much HP. For comparison my last AMC was this:
360, stock dog-leg heads (outflowing your ported heads by a lot), Performer Air-Gap, Reed flat-tappet cam, stock bottom end (8.5:1, fresh rings/bearings and ARP rod bolts), 780cfm Carter, Hooker long tubes, etc. put down about 350HP to the wheels with a 727 Torqu-Flite trans. That engine is 9ci up on you, larger bore, better heads, bigger valves, and a bigger carb.
I highly doubt you're anywhere over 300 without a truely radical cam, and it sounds like a plain, low duration, low-lift, flat-tappet one to me.
Reply #149
Daboss,That's the way it goes sometimes.Take your time plan things.A lot of people just start bolting things together and don't get anywhere.Bigger isn't always better.
