Topic: 5.8 Fastcat #2 Winter Work (Read 43768 times) previous topic - next topic
Reply #120
Lookin good,You should be proud.
Reply #121
4.6 T bird;  The air ride came from AirRide Techonolgy. The kit was designed for a SN95 Style strang. I had to modify the caster chamber plates.  The reat fit pretty well.
  The kit was $2300 with E ride and the frt air struts. You can get air bags for the frt and it makes it consdible cheaper.
Thanks Guys
Reply #122
Fast cat you should post in the at the track section i think your car would take number one of the forum.
Reply #123
sweetness! I can't wait to see your finished product. Looks good
Reply #124
I wish I had your budget.I'm building my car on a $1700.00 budget.
Reply #125
When you are doing most of it your self that helps the budget ALOT.
 I've paid for the paint,rollbar and powdercoating. THe rest is on me.
I also bought the  Baseline Suspion stuff.
Reply #126
Right now,I need to locate a TC header panel,and a passenger side fender.That's it,then I'll get the bodywork finished and out to paint.This weekend,weather permiting,we're swapping in the engine.After that,it's all easy.
Reply #127
Here are some pic of the rear susp.
Reply #128
That's pretty.Nicely done.Where did your tailpipes come from?I need to get a set for my car once the engine is installed.2 1/2 inch if possible.
Reply #129
Greg what is the point of the "red thing"?  Does it allow the use of mustang uppers?  Is that for better geometry?
Reply #130
thats a nasty four bar set up.
Reply #131
CougarSE; The red upper relocate the upper arms giving the ctr arms more leverage on the reaend to plant the tires better, also changes the instant center off the car keeping it from hitting the tire hard and then unloading the tires.  ??????  Time will tell if it will work well on the Cougar.
Vinnie; The tailpipes are for a Stang, they are 2 1/2 in Mandrel bent.
 They were straight out and I added the turn downs.
Reply #132
So,did the Stang pipes fit well without any mods,other than the tips?Thanks.
Reply #133
Yes, They fit well.  I also run an Exhaust shop/Dyno shop so this helps.  LOL
Reply #134
Quote from: vinnietbird;128040
Not sure if you saw this in another post - but these 2 1/2" tailpipes http://store.summitracing.com/partdetail.asp?autofilter=1&part=FLO%2D15814&N=700+0&autoview=sku + these 13" long tips http://store.summitracing.com/partdetail.asp?autofilter=1&part=FLO%2D15362&N=700+0&autoview=sku seem to do the trick.
Just an option...sorry for the hijack...
