Topic: The Fila Project... Wondering why Fila was banned? Read the last few pages (Read 148370 times) previous topic - next topic
Reply #345
So I am guessing that your car is running and everything no or what's goin on.  Long ass thread and it trails off onto different things. Kinda hard to follow.  But looks like you doing a good job.  I am starting to do the same thing as you.
Reply #346
It does drift off a few times. The car *runs* but isn't running. Need to get gas and tune the carb, put the H pipe and flowtubes on, then tires and I'm good.
Reply #347
Mini update. Coil was deat. Got the car to turn over today, it tried like a champ but never fully started. New coil, plugs, and maybe try a different carb tomorow for the hell of it. Oh what a fun project this is turning out to be
Reply #348
How's the fuel pump?Accelerator pump?
Reply #349
On the car, eclectric fuel pump is good, Accelerater pump is ok I think. The main things that I think killed me are the dead coil, almost dead battery, mismattched plugs ( some new, some not), and the fact the carb is untuned to this motor. I'm trying a freids holley toomorow. It just came off his car so if anything will run the Fila, that should
Reply #350
Reply #351
Getting some tomorow while I get other stuff. I've almost given up for the day, theres not too much more I can do right now. Oh yeah for the 3G swap, does teh car's black and orange wire go to the battery also? I have it all hooked up but I swear that gets hooked up too. Anyone have any idea's on what I can do to the car in the rest of tonight, almost broke with all the parts stored closed?
Reply #352
are you and Daboss351 related?
1979 Ford Fairmont
[/B]
Reply #353
Nope, not at all, we just talk to each other alot, why do you say that?
Reply #354
Quote from: 32VFoxBird;142403
That was random.... Nope. As for starting the car, it did start and ran for almost 5 min's.  me and Brian are good. My god are those Mac's loud with ONLY that as an exhaust:D . Also need valvecover gaskets, mine suck. As it ran they bled onto the new headers. ....:toilet: Oh yeah, when you turn the key sonmetimes the car will turn over, sometimes nothin. Motor is fine, if you jump i toto the battery it works fine. Any idea's on that one also?
Reply #355
Quote from: 84 Fila;142417
bad battery cable or switch.
1979 Ford Fairmont
[/B]
Reply #356
Cables are good. Everything else works by key. How hard is it to replace the switch, I'm assuming you mean ignition switch?
Reply #357
I was wondering if you and Daboss were related as well.Anyway,the ignition switch is in the column and is held on by two safety torx screws.Takes all of 5 minutes to change it.If you've never done it before,it may take a little longer.I'm sure Brian knows how.Does he get the credit for getting the car to run for 5 minutes?Take a break for the night and get some rest.
Reply #358
Don't go tearing the column apart yet, Mike.  I think first you oughtta make sure you have a good solid connection on the starter solenoid.
Reply #359
Just checkin out possibiltys guys. We'll figure that out today. Then on to Brians to play with bushings
