Topic: The Fila Project... Wondering why Fila was banned? Read the last few pages (Read 148350 times) previous topic - next topic
Reply #375
I doubt all of your plugs went bad,even if they sucked,it should still run.Throw another coil on.What kind are you using?The EFI style or the old school type?
Reply #376
We rigged up his old CFI/EFI style coil and it worked great.  As I understand it, coils either work, or they don't correct?
Reply #377
Works yes, but I have no idea how many miles are on that CFI coil, or how many were on the old school one either. Brian, you were here when the old one dies, it's doing the same thing. I'll snag another EFI coil from the JY tomorow and do some rigging and see what I get. Once I get cash new plugs and coils comes
Reply #378
Quote from: Ifixyawata;143444
yep,, and if it passes the primary/secondary resistance check.
Reply #379
Reply #380
Think I found a cam I like, for a price I like too.
NIB comp cam
292 duration on both sides
.534 lift on both sides
253 duration @ .050
110 lobe sep.
hyd. flat tappet
With lifters
Anyone think this would work?
Reply #381
that cam is far too big for anything you have
Reply #382
Quote from: Tbird232ci;143579
:stupid:
1979 Ford Fairmont
[/B]
Reply #383
Ok, got a new coil today and coil bracket. bolted it in and the car started right up. Runs 200% better. Now tomorow I can tune the carb and be set. Not a bad day, just didn't get alot done
Reply #384
did you buy that h pipe or what?
Reply #385
Going to. Running came first. Should have money out this week r early next
Reply #386
ok just making sure cause i should have a envelope with cash tomorrow from my dad, and conformation party next weekend so im gonna have some money, and its almost all gonna go into the lincoln
Reply #387
If you need it man, take it. I'm not going to be a prick about it. I wanted it, but if you have cash first, more power to ya. Before I could get it, I need a Lokar cable for the trans, a full tank of gas, alittle more wiring stuffs then I could get it. That and I think I finally found a DD I like. 85 Ranger 2.3 Auto with floor shift. Im talking to the guy tomorow but for $300, who can complain
Reply #388
ill see what happens if i get it, i promise ill send my original one your way, with the flowtubes. all depends how much i get, because i have to get the rest of the odds and ends for the car. we will work something out bud
Reply #389
Were in the same boat bud, don't apploigaze to me ok. I'll take what I can get, when I get it
