Topic: The Fila Project... Wondering why Fila was banned? Read the last few pages (Read 148400 times) previous topic - next topic
Reply #330
Just curious but I don't see a mounting point on the carb linkage for the TV rod to your transmission. You say you have been having problems the tranny and that could be one of them. I think I've read in the manual that extended driving with that unhooked can ultimately damage it. Might be worth looking into.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
Reply #331
Please tell me those wires aren't just twisted and taped together.I actually like making wiring harnesses (I'm sick that way),and it sure pays to do the wiring right.I use a solder gun,heat shrink,then i wrap it all up witha factory style tape.I like the plastic wire loom in moderation,but some people get a little carried away.Check any tuner car.It takes a while,but,do it right the first time and you don't have to go back and do it again a second time.Spend a day off from the mechanical side of this car building and do some wiring improvements.It doesn't cost much,and the looks and function can really make a huge difference.You really need to go the extra mile when you're doing your work.Doing the work half-a$$ed really shows.
Reply #332
Believe it or not, Vinnie, I've seen that car run with twisted-together bare wires.  It's not safe at all, I'm sure, but it ran... once upon a time.
Reply #333
I have no doubts that it runs,I just want to see it cleaned up.......by Tuesday !!!LOL.
Reply #334
You and me both.
Reply #335
had no time to pull off the flow tubes, had to much shiznit to do, went to see horses wasted half the day, drove back and forth for parts they didn't have ugh.
Reply #336
The wiring will be done right after the car starts and runs again. The tv rod isn't attached because I still have to hook it up. This is far from done, just what I got done today. Tomorow should clean this up ALOT more then I did today
Reply #337
Quote from: Tbird232ci;141859
Go and buy some wire loom, and some zip ties. It looks like  under there.
And a can of engine degreaser...
Glad to see progress though. Keep it up.
Reply #338
Going to simple green the hell out of that montor some time next week. I know there is white paint somewhere under there. Might even clean the wheels and valve covers.
Reply #339
Got all the wiring cleaned up, teh sub and amp wired in, motor alittle cleaned up, center caps on.... waiting to scrounge up gas money and fire the beast
Reply #340
Scrounge money for gas?Don't you have a job?ALWAYS keep gas money aside.A cool car isn't any good if you can't drive it.LOL.
Reply #341
This car reminds me of darkthunder in it's early stages... wish I could find a pic.
Reply #342
Someone check me on this, but that is a 7.5" rear right?
Reply #343
yup not only does it look exactly like mine notice how its round on the left and suddenly becomes horizontal. 7.5":D
Reply #344
Things for the future are edelbrock adapters to get the throttle and TV rod to work with the carb, and hopefuly a floor shifter soon. Then either a Mac H pipe or a Mac Prochamber, depends which gets here first.
