Topic: The Fila Project... Wondering why Fila was banned? Read the last few pages (Read 148402 times) previous topic - next topic
Reply #315
I was sure that the chambers of the GT40's were larger than that of the E7's, im not sure about the heads you have now though. I do know for a fact that the GT40P's raise compression a good bit.
Reply #316
I heard that even though GTp's need the " sepical plug wires", that I can use them in the bird wit teh Mac headers because there is room. Is this true or stright BS. And can a stock cougar shortblock handle the higher compression?
Reply #317
FYI Mikey, that Cougar block and any '84 block (probably '82 - '85) are exactly the same.  And yes, that compression shouldn't be an issue with that block.
Reply #318
Compression is no big deal. If you run the P heads, you you to use 90* spark plug boots, and in some cases, you might still have minor issues with it. Ill be finding out eventually.
Reply #319
With the GT40P heads,you'll need the Ford Motorsport headers.the plugs go in at a different angle on the P heads.
Reply #320
Quote from: vinnietbird;140199
Ive heard the motorsport headers work best, and Mac sells headers for the P heads, but through the grapevine, ive been hearing that you can use 90* plug boots and shorties.
Reply #321
Same thing I heard. I just don't wana have them on then have to find out the hard way that I need motorsport headers. Just don't have the funds for it right now. If someone else can prove they work with 90* boots and Shorties, I'm game
Reply #322
i might be able to in a week or two
Reply #323
Thank ya much. Please let me know
Reply #324
Got the 3G in the car today, new door speakers mounted, pics of the headers in, cleaned out the trunk of the car, and did alittle finishing wiring. Not even half way through the day either
Reply #325
Im gonna go get some stuff for the lincoln, shove it in the driveway and work on those flow tubes for ya bud!
Reply #326
Reply #327
last 2 pics are for Mike, he wanted to see my 2 different tail lights
Reply #328
3g still needs alittle more wiring and the E fans need a relay but thats about all I did so far today. On the 3g side, does the b/o wire go to the battery too?
Reply #329
Jesus christ dude. Go and buy some wire loom, and some zip ties. It looks like  under there.
