Topic: speed govenor (Read 2929 times) previous topic - next topic
speed govenor
do all thunderbirds have one? mine does. and how do you get it off?
how much would a whole new racing computer cost?
speed govenor
$1
speed govenor
oo wow, i dont have that kind of money. would it work if i just splist the VSS wire?
speed govenor
why remove it?
speed govenor
Top speed isn't all it's cracked up to be.  The worn suspension and brakes on an 18 year old car are much scarier at speeds of 80+.
speed govenor
Si, but like Ifix said you may want to make the car ready for that kind of speed before actually achieving that speed.  I'd also recommend mayhaps doing ridiculous speeds on a track on a test & tune day where you are legally allowed to do so.
speed govenor
yeah, i want it off because i want to start draging my car. i want to get a mustang computer for it.
speed govenor
Unless you have serious mods you arn't going to hit thw 120mph speed governer on these cars by the end of the 1/4.
speed govenor
I hit 325 mph before the 60ft mark with no speed governor.
speed govenor
Quote from: quicksilver
A Stang computer will not work on a SO Tbird engine... You HAVE to do a HO upgrade first...
speed govenor
Quote from: slamedcat
The governor is set at 182 KM/H or about 112-113 MPH. You aint doing that by the end of a 1/4 either :)
speed govenor
Quote from: Ifixyawata
Pffffft, that ain't nothin'...with my Allison V12 powered tricycle, i can hit 750 mph in 10 feet...;)
quicksilver, is this your first car?
speed govenor
yep first car, but my govenor is set at 85 mph, not 112-113.
speed govenor
Hmmm? I think you might be looking for the Bondocougar mod. I'll try to find it for you.
EDIT: I can't seem to find it right now. I'm pretty sure the governor is at 182 KM/H - I've tripped it many times. When the governor engages the engine just goes back to an idle even though you have it at WOT.
You have the digital speedo, right? and it stops at 85 mph? but the car keeps accelerating beyond that.
If you want the speedo to read beyond 85 MPH you will have to do the Bondocougar mod. The gest of this mod it that there is a spot on the speedo circuit board marked W2. If you solder a jumper in that place the speedo will measure beyond 85 MPH.
speed govenor
Yes, Paul is right.  The car only reads up to 85 but it will hit higher speeds than that.  Though it's not really safe to go too much faster.
