Topic: speed govenor (Read 2959 times) previous topic - next topic
speed govenor
Quote from: Ifixyawata
Though it's not really safe to go too much faster.
When I engaged the governor, the car was only a year or two old.
With the worn springs, shocks, frontend, etc. I don't think I'd try it today.
speed govenor
well, i have brand new racing shocks on it. i have a new front end.
where would i buy springs at that will fit a tbird?
speed govenor
Search the forum for info on what mustang springs work.
speed govenor
so i took the bird out for a spin, and the car stopped pulling at 85. it stalls out. is their after market parts to make it do this?
speed govenor
Do you have a digital or buttstuffog dash cluster?
speed govenor
I did the mod on my speedo.The jumper wire is an easy job,you just have to be VERY careful not to solder anything else,as the two points on the circuit board are very close to each other.I got mine up to 144 so far.We'll see what happens after the new ported and polished heads are installed.I do the conversion on the standard speedos and put them on E-bay for $20 -$25.You have to disassemble the gauge cluster,remove the screws in the back of the cluster to remove the speedo module,and unplug the tiny harness that connects it to the rest of the cluster,then,disassemble the speedo by removing the "green screen" as i call it,and gently popping the little whit plastic retainers apart that hold the circuit boards together.You must be careful,or you're screwed.On the circuit board,you'll see a tiny little "W2.Next to it are two small "solder dots".Connect a little jumper wire between them and then the gauge can read up to 199 mph.I should've taken pics.I think there's a tech write up on the cool Cats tech center.I'll try to find the site for you.
speed govenor
I got factory replacements at the parts store. I can't remeber the number but I know they are MOOG brand.  They even list the T/C with differnt springs that the regular bird/cougars
speed govenor
Quote from: slamedcat
it is a digital.
speed govenor
It will go past 85mph. When you are going down the road and hit 85 push teh E/M button on the dash. The numbers keep going. You need to do the mod to make it read past 85 as stated in a prvious post. This should help.
speed govenor
i have the same prob. with my 94 3.8L Cougar. i hit 110mph and got plunty of rpm left. rebuilt most of the under side of the car,even new lover control arms, every thing i didnt do was done defor i got the car.  now how the f*** do i get rid of the governor. off topic is there any web site in can get any thing aftermarket to get the h.p. up? did the hole k&n thing and made my own exhaust. thank for any help you can give.
speed govenor
geesh I got 55mph and i get pulled over.... 140! 110!  i wish i lived where u guys do.
If your car is stalling and messing around after 85 u may have another problem?
speed govenor
I-35 runs through the center of Oklahoma from Texas to Kansas.LOTS of straight highway.Not many Highway Patrol.It doesn't take long to get the speed up then shut it down.Very cool,and a little scary with my stock suspension......but cool.Anybody with the standard gauge clust REALLY needs to do the 199mph mod.It's very easy,takes about 15 or 20 minutes if you take your time.Worth it.
speed govenor
Not a single one of these cars "stall out" at 85mph. My 3.8L did better than that.
Racing struts but stock springs? New front end and stock springs? I think someone is full of it.
