Topic: Sn-95 T-5 swap behind 3.8 Cougar/Bird How To. (Read 100666 times) previous topic - next topic
just got a chance too read through the thread...gongrats guys...awesome work!
~John~
Quote from: darkthunder
ooo nice. it looks stock minus the shifter. looks like your parking brake works too. *envies* :D
That shifter is off of a probe.  It was the only thing that would screw on.  I'm going to get a bullit shifter  for it.  I'm going to get a nice shifter for it as well.And yes my parking brake works.  Every time I'm under the car I spray lubricant on the cables and bell crank assembly.
well is the 87 and older 3.8 a 28.5 inbalance? should be able to use the 351 flywheel. I see that the 3.8 has a 11 inch disc. isn't that what they used in the 351 truck?
Quote from: TCclone
No, it isn't a 28.5oz imbalance. Ford has used several different imbalances on 164 tooth flywheels.
Also the 351 flywheel will not bolt up to the 3.8 right Jeremy?
Hey, Claude, how is going the living with the car now ? you can tell us some "driving impressions", how the 3.8 responds to a T-5, how high you change gears, the torque things, how feels in Overdrive, etc...
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
Stupid question: is that the automatic console trim cover?  No interference problems with it and a manual tranny?
pro-five-oh
Nice job on the swap. I'd try and do something about that big crack in the firewall though.
Pro-Five-oh :  Yes its off an auto, It doesn't hit anywhere.
Dogcharmer :  There isn't a crack on the firewall, probably one of the shadows making it look that way.
Mex Cougar and others :  The car drives 100% better.  I don't find myself having to downshift to climb hills anymore.  The car just feals more powerfull.  Only problem is having the auto computer, I described the problem in another thread with more detail.  I've actually not shortend my driveshaft yet, and I'm starting to think I don't have too.  What I previously though was a noise coming from my U-joints is actually an effect of my bad motor mounts.  the shifter base is actually moving over and rubbing the transmission tunnel.  New motor mounts will fix this.  I don't have a tach in my car yet, I'm working on that.  I drive by the sound of the engine right now.  Gas milage is a bit better too.
Reply #39
Quote from: CougarSE
Excellent.  Good to know the trim plates are interchangable.
pro-five-oh
Reply #40
Hey sup New to this site... Got a question for anybody who wants to reply... Question is I have an 84 thunder bird and I wanted to know what would be the best engine to put in it and what tricks I could do to make it go faster?  and If possible could I run nitrious through that?
Reply #41
Quote from: 84_T-Bird
What exactly does this have to do with swapping a T5 behind a 3.8?
Reply #42
I cannot believe you tainted my thread.........ugh
Reply #43
You should send this Step by Step to Eric at Coolcats and get him to set it up in the tech area. Very worth while information for long term use!
 --Ed
"1FSTCAT" - 87 Mercury Cougar XR7, 5 Speed, Powerdyne Supercharger.
"NTRCPTR" - 91 Crown Vic Police Interceptor - 460 POWERED. 14.15 @ 97 MPH, untuned.
Reply #44
Sorry if this comes off sounding like a twit, but can you fix the pictures?
And do you have any additional information on interchangibility between AOD flywheel vs C5 flywheel?
