Topic: Sn-95 T-5 swap behind 3.8 Cougar/Bird How To. (Read 100528 times) previous topic - next topic
Reply #60
8 years later and I still haven't put a manual behind my 3.8! :toilet:
Reply #61
Quote from: JeremyB;433419
Well your title does say procrastinator!
Reply #62
I've probably bought 6 cougar/birds since this thread started... but i have done a t-5 swap.;)
Reply #63
I love my T-5 swap... At least I think I still do. We'll have to see once it's back on the road under EFI power!  :)
Reply #64
are you still running the carb setup on your 03 motor?
Reply #65
wow didn't you start that like two years ago?
Reply #66
Quote from: sarjxxx;433421
Yes, the Split Port that has been in my garage since 2009 isn't happy with me!
Reply #67
wow! so since you are not going to use it, can I have it lol
Reply #68
I'm gonna use it... eventually.
I just need to finish the CFI 3.8L upper end rebuild, throw in a T-56, blow up the CFI, then swap in the SP. :mullet:
Reply #69
lol that sounds like quite a plan, good luck hahaha
Reply #70
Quote from: sarjxxx;433447
Well...I might have picked up some parts for it about two years ago or so, but the distributor has some stupid thing wrong with it so that it won't pass DEQ and it would cost me almost as much to replace it as it is to just put the injection on it.
  So I have finally torn the top off and right now I'm working through a sensor signal issue before it will run.
Reply #71
wow... glad I don't have emissions down here...., only good thing about having a vehicle in Florida, they certainly know how to get you every other way though
Re: Sn-95 T-5 swap behind 3.8 Cougar/Bird How To.
Reply #72
Five more years gone, and mine is done before yours!  :laughing:
https://media.giphy.com/media/pQmWjYrz39YAg/giphy.gif
Reply #73
If this was addressed and I missed it, I apologize.  The one reference I never saw was to the C5 trans, which is what my '86 GS 3.8 has.  It seems like everybody else who's done this swap had the AOD.  What is the proper imbalance for my application?  And how does the length of the C5 compare to an SN95 T5?  I hope I'm not the only one who's starting with the C5.  Thanks.
Reply #74
C5/AOD is irrelevant.
Imbalance is with the engine flywheel, not the transmission torque converter.
C5 is shorter than the AOD. You'll need a shorter D/S.
You may have to cut the tack welds on your crossmember to move the mount back.
