Topic: intercooler for KB blower (Read 5861 times) previous topic - next topic
anybody have a kenne bell blower know if this would work? if i end up getting one, i would like to be able to have an IC for it... and sence they refuse to make one, i might end up haveing to. just got to think'n today...
Did you read their FAQs?
Why doesn't Kenne Bell offer intercoolers? We do. Kenne Bell has been selling our own air to air intercoolers for the Buick GN for 13 years - and the Syclone/Typhoon for 10 years - well before the supercharger industry even considered intercooling. If intercooling was the way to go with our Twin Screw Supercharger, we would be using one. There are 2 ways to approach supercharging: 1. use a supercharger and/or boost that won't work without intercooling or 2. design kits with a supercharger that is efficient enough that it doesn't require an intercooler. Kenne Bell has chosen the later. First of all, contrary to popular belief, intercoolers do not "make" more horsepower. They cannot. Supercharger output is FIXED and doesn't increase merely because downstream air charge temperature is lowered. It's the same air by mass. The mass, the weight, the oxygen content of that blast of air discharged by the supercharger cannot be increased. You don't believe it? Try this. Capture the discharged air in a bottle, seal it and weigh it at 300°, 200°, -50°. The weight (mass) won't change, the engine can't ingest more air so it won't make more power. Yes, the cooler denser air, at -50° for example, will "allow" more boost or advanced engine timing but that air, by itself, won't make more power. Now if the air entering the supercharger (ambient) is reduced, it is denser and cooler and then will make more power (1% increase for every 10° temperature drop according to our data). So why intercool? If the supercharger is relatively inefficient with a high discharge temp and the engine knocks at 6 psi, then the air charge temp must be reduced. Retarding ignition timing or lowering the boost to 4 psi reduces power, so that is not an option. Fortunately, the Kenne Bell Twin Screw is the most efficient supercharger concept available being around 60° cooler than the competition at 6 psi, so an intercooler is not needed to remove an extra 60° from the air charge.
If I ever found myself able to afford one of their blowers, I'd probably use that (on top of a GT40 lower intake) plus one of their Ram Air kits.
but that dosnt count for the blowzilla does it? i mean, after a cirtain point that air is going to get real hot, and haveing 12+ psi will cause problems wount it? why else would some of the guys running more hopped up setups have to run water injection or alachol injection which i hate.
kenne bell makes some of the worst 5.0L blowers for power production . Look into the ati Procharger. about the same range and a whole lot easier to use an intercooler.
I would think you'd have to ask them that. It was never my intention to run more than 6-8 PSI, if I got one of those.
Quote from: SLEEPER T-BIRD 87
But he didn't ask about ATI Prochargers, now did he?
Quote from: Bird351
I just stated an opinion if you dont like it dont respond to my post
I was just was saying in the long run it may be cheaper.as the kenne bell is expensive and the ati offers one with a intercooler kit also for about the same cost.
And to add to this anything can be done if you use you imagination.
If you can't handle a little criticism, I suggest you not post in the first place. If you make a public post, you had better be prepared for public response.. good AND bad. Welcome to the Internet.
It's one of my pet peeves around here that people don't even bother to address the topic, they just say "it sucks, buy/do this instead".. well what if he, like me, does not want a ed centrifugal supercharger? Then you've given him useless "advice". (more like opinion passed off as advice.. and you know what they say about opinions) At least attempt to open a dialog on what to do with the KB, before pushing off your opinion as advice. Some of the other readers here, like myself, (only interested in a KB supercharger, if I get any supercharger at all) might be watching this and hoping for decent feedback.. so you're not only screwing the original poster, you're screwing anyone else who might get use out of this as well.
Yeah, maybe it's unfair I'm taking out my rotten mood on you by calling you out on this.. but deal with it. I'm dealing with far worse than being called out on a bad post, right now.. you can deal with a little criticism.
Quote from: Bird351
It's one of my pet peeves around here that people don't even bother to address the topic, .
I did adress the first post. so quit mucking this mans thread up .
Quote from: Bird351
I really do not care about your problem like i said dont like it keep your mouth shut.Period. if you got a problem please feel free to send me a p/m and i will help you adress it in private.
ok, so....
sleeper, im interested in the twin screw setup for its clean apearance, and its simple ducting. those centrifugal blowers just seem too inefficiant and have alot in the way. besides, i'd have to put money into a higher flowing upper intake where as the twin screw is the upper intake. but thats just my opinion.
and besides, i dont even know if what i posted above is possible. i know somebody hear has a kb setup... i just want to know if what iv seen in all the photos is true, and if i ever do get to a higher boost application, i would like to be able to modify it for a intercooler. i plan on running it for a while wthout one, possibly selling it and buying a bigger one when i go to a 408 down the line... maybe in 3 years or so. anyhoo... its all hypathetical so try not to kill each other over a stupid question. :D
Quote from: Manson
ok, so....
ok man.
What lower intake will you be using you could probly fab a elbow kind or what is used on the powerstroke diesels. Just an idea good luck on your project.
You know what? **** you, Asleep at the wheel. Welcome to my ignore list, asshole.
well if i do this, i'll be useing my gt40 intakes lower. so its gonna be ported out and puddle welded. then probley go and port out the kb air exit manifold and then i dont know, fab up some duct work, and yes lol, i was thinking of that elbo like the diesels have, except i got the idea from the fulie 460 intakes. if only i were rich lol, id be playing around with it rite now. maybe i can patent the idea and make the money back for the blower lol.
ok man.
Quote from: Manson
ok, so....
It doesn't look like it's possible, just looking at the bolts holding that part on.. the part you want to switch. The upper (in your pic) bolts are in a line, and the lower bolts are in a ^ pattern. However, I'm sure pretty much anything's possible with enough tinkering. If you did manage to make it work, I'd be interested in how tough it was.. and how much of a difference it made after the effort. They may say an intercooler isn't necessary, but why not try if you think it's worth the effort?
Sorry for the rest.. but I'm in no mood to put up with this guy's shiznit. Frankly, if he had mouthed off to me in person in the mood I'm in right now, I'd have outright shot him.. I'm in that bad of a mood.
Quote from: Manson
yeah, It will probly take a ton of fabrication but should be worth it in the end.
