Topic: intercooler for KB blower (Read 5820 times) previous topic - next topic
Reply #45
Quote from: Manson
even if it was just constant, you could hook up a fan with a thermostatic switch  on it. im sure running that pump constantly would keep the fluid pretty cool unless you were realy pushing the car for an extended period of time, like on the highway with gears. but in going that root, you now add the weight of a intercooler, and a radiator for the intercooler, pluss the fluid for it. seems to loose efficiancy having to add something else to cool the cooler. personaly i think it may be better just to have the ducting and run a front mount, instead of haveing it ontop of the motor, then running lines, pump, and heat exchanger with maybe even a fan.
I don't think you can really beat hte setup on the 03/04 Cobra motors / Lightnings.  All the 'big' HP guys keep the factory intercooler setup.  This includes the guys going to turbos, centrifugal etc.
Ryan[/i][/COLOR]
1986 2R[/b] SVO
1984 T-Bird 5.0 (In Hibernation since 10/96)
