Topic: 87 "coug" resto winter project (Read 121205 times) previous topic - next topic
Reply #120
had the garage at 70+ degF for 3hrs,, perhaps the metal was too cold still,, dono
going out now to touch up with a roller in the problem areas and then ignore it for a few days
hopefully the problem will go away on its own, otherwise I have to s it all off.
Reply #121
Lots of sandblasting complete on the whole driver side
Reply #122
I know its a day late and a dollar short but I would have welded up the ends of the tubing you used for the sub frame connectors.
Darren
Reply #123
The tubing that goes up inside the car is open,, that end tilts uphill so to speak.
the rears are still open, there is an end cap that I can buy to pop in the tubing, friction end cap,,,  I can silicone it
I plan to drill a drain hole in the tubing somewhere towards the rear
Reply #124
Got some more cleaning done and a coat of primer on the driver side
Reply #125
I didn't realize there were so many drain holes on the rockers...
btw,, to access the tunnel in the rockers to blow them out, there is a rubber plug inside the car frame just inside the door hinge area  and down very low.
this was very handy to blow out any objects in there.
I stuffed my screw driver up inside the rocker drains and formed them just a tad larger.
I am spending a lot of time noticing the drain holes and placement to A~ see if they make sense and B~verify they are not clogged or can be clogged in the future.
Reply #126
this stupid bed liner stuff is still kinda wet..  me off.
I feel like I paid 69$ for a gallon of stuff I must not be qualified to apply apparently.
if the truth be told I think it doesn't like being put down on fresh primer.... gotta call rustoleum and ask them what they can advise me on.
Reply #127
I covered a whole truck (30' long or so straight truck freightliner) when i was a shop bitch at one of my last jobs. We had a 5 or 10 gallon bucket. We had to mix it really, really well with a paint mixer. The gritty thick stuff would settle to the bottom. If i let it sit for 2-3 hours, i had to mix it up again.
Reply #128
what kind of primer are you using?
Reply #129
Rustoleum sandable primer with filler
I'm using it from a spray can in the low visible areas
Reply #130
Passenger side is sandblasted completely underneath
No picture but it looks just like the Driver side
Reply #131
The bedliner stuff is starting to dry
I guess it has to do with the moisture in the air or something
Reply #133
you'd be better off finding another trunk lid that will never stop rusting unless you dipped it in rust desolver.
I dipped my replacement door bottoms for a week  to get rid of minor rust
I ended up cutting the entire bottom off my trunk lid, and rebuilt it in all new metal
Reply #134
trunk lid rebuild
http://s233.photobucket.com/user/daminc/library/trunk%20lid
