Topic: 87 "coug" resto winter project (Read 138885 times) previous topic - next topic
Reply #91
Just weld in the subframes ah-la what I did. It's plenty strong. If it works fine on my Thunderbird it will be fine on your Cougar :). Just remember before welding in the subframes the weight of the car should be sitting on all four tires.
Reply #92
welding in the fronts only leave the rears not welded, then when weight goes on wheels, weld up the rear then.
sound ok?
Reply #93
this fuel pump access lid is kicking my ass..... trying to think "how water" swings up above the fuel tank and mitigate that possible water intrusion.
I have seen all things from gravel to dirt up on top of a fuel tank.......so..........
I am thinking that my steps this afternoon will be ok with the cover but when we install the fuel tank, there will be a piece of flashing added on the bottom so nothing can get on top of the fuel tank.
Reply #95
Quote from: jcassity;442197
sound ok?
Maybe? I would message Jerry and see how he welded his in. I believe he did it with his car in the air so he may be able to give you some insight as to what procedure to follow. On my car they were welded in with all four wheels sitting on a drive up lift so the car's weight was on its wheels.
Reply #96
I'm satisfied with this
After silicone is added and flashing on the bottom it should be okay
Reply #97
I took a couple phone calls today about subframes
My car is level right now left to right and from front to back so I don't see a real issue with it
My doors also open and close real super easy so it leads me to believe I'm already level with how the car wants to be setting
I'm moving to subframes now since I have completed the fuel tank access
If anyone else wants to give me a buzz or talk me through some problem I'm not seeing yet then give me a call at 304-772-3411
Reply #98
Primer is down
Now to decide if it goes to gloss black or truck liner
Reply #99
mine were welded with the car sitting on 4 ramps sitting normal
Reply #100
Thanks!
it just occurred to me we are starting with the same car as yours,, and it seems we are ending towards the same color and wheels...
interesting.
well, back to work, hopefully the doors and trunk get repaired after the fronts of the sub frames are nailed.
Reply #101
your starting with way more car..... I'm enjoying this thread very much. keep up the good work
Reply #102
I think you guys just like to be alone in the garage with a Foxy ole Cougar. ;)
Scott, what's the deal in lewisburg? Sounds like some pretty crazy stuff. Two bodies in the truck, the guys shooting at cops and running..etc. Interstate whiskey deal gone sour? Or just more crazy shiznit?
Stay safe!
Reply #104
Quote from: daminc;442327
all it takes is a good tolerable transmission line leak & oil pan leak to save the chassis of any car.
so...... if you don't mind, I may ping you about things Ive noticed.
-what logic was used in the fuel tank forward support brackets? the pass mount is welded and designed different from the driver side
-how did you end up offsetting your sub frames forward to aft since the rear frames are closer than the fronts?
