Topic: 87 "coug" resto winter project (Read 121715 times) previous topic - next topic
Reply #105
i know that the pass tank mount is smaller...people were saying there was a bit of an issue making the exhaust work with larger pipes, and I was trying to copy them as close as I could to the originals for looks... I'll have to go back and look at the pics
Reply #106
the subframes arent offset, they run straight to the back and I welded a bracket to the rear end of the subframe to match up to the rear frame.. they are actually partially inside of the front frames too
Reply #107
this is how they connect in the back and through the floor i used this to show that they are a full 2-1/2" offset from the front, I made a plate that welded along side the rear frame
Reply #108
triple checked my level again,
with a high quality wide arch sight glass 2' level, I am dead perfect left to right and front to back.
on a side note......................... this is another stupid thing I noticed last night.....
if you have your bumper cover off,
did you all notice that the bumper itself is high in the middle?
I laid my level directly down on the bumper itself and my level ever so slightly rocked left to right so I looked and sure nuff, the center of the bumper is higher.
so.....I scooted my level back a little and got a good measurement.
Reply #113
I have wrinkles in the metal on the pass side transmission tunnel.
pls don't tell me my old 3.8 did that>?
look at the last picture.. the wrinkles go way up.. wonder if that's a factory stamp out mistake or just a small issue that when the metal was squashed up to shape it, the slack  had to go somewhere.
Reply #114
Those look like production issues but one quick way to tell is to cross measure the car and make sure it is square.
Darren
Reply #115
Quote from: jcassity;442389
I *think* both my Thunderbird and Mark VII have that same wave/wrinkle in the metal in the same area. Neither of my cars have been wreaked.
Reply #116
Rears of the subframes are welded
Still need to shoehorn in some vertical plates
The trunk now has bedliner all over it except for the upper half which will get gloss black
Reply #117
boy oh boy do we have a problem.
the rustoleum bed liner stuff is not working well on vertical surfaces.  its running down the sides and leaving gray streaks showing from the primer in behind.
its pooling up where it settles.  I have no idea what went wrong.
min temp requirement is 55degF
says you can roller it on ect , prep surfaces and if needed do spot prime in areas.
says you can use the rustoleum applicator kit or a roller, I used a brush, I had a roller but the brush was going really fast.
I mixed up the stuff real good and even kept a paint stick in the can to keep mixing it up so it doesn't settle or separate.
Reply #118
only time rustoleum seems to go on well is spraying through a paint gun, I've never got a decent finish using rustoleum either...well except for satin black spray can on a very hot summer day
Reply #119
paint will generally slide off a vertical surface if its to cold compared to the air temp around it.... whats the temp of the shop?
