Topic: New Here 83 Thunderbird (Read 69995 times) previous topic - next topic
Reply #165
My caster camber plates came in Monday, I will posted some pics up soon when I install them.  Ordered them from JD's performance, they drop shipped from Maximum Motorsports.
Reply #166
X
I added a new fuse holder, replaced the one that melted from E-fans.  I went with a blue-sea brand one 30 amp per and 100 amp total. I also we routed the wires so I could but it in the truck area with the battery.  I ran an 8 ga wire to it from battery and 10ga wire to the accessories.  I am running my low and high headlights, fog lights, fuel pump, and a 12volt accessory with relay.  I just have it temporary where it is in the picture, left enough wire so I can move when I started putting interior back in.
Reply #167
X
X
Well I received my struts today, and I scored some 13 rotor and calibers that will be here on Friday.  I also got a speedo plug for the T5 since I am not running a speedo.  I also got the proportion valve plug and sn95 brake line adapter.  Waiting on front spring isolators.  I will get some 94 ball joints also.
Reply #168
The brakes are gonna be a huge improvement man!  Cannot wait for pictures of them installed!!
Darren
Reply #169
Darren you know I will get plenty of them, lol
Reply #170
Started on new brakes and caster camber plates
X
X
Reply #171
X
A little tease, lol
Reply #172
I love how those calipers just pop
Reply #173
Quote from: Ramos617;447996
Thanks
Reply #174
X
X
before and after CC plates
Reply #175
finally strolled back through this thread,, its amazing how much time it really takes to restore.
way back when I saw your power distribution block I wish I would have posted back then with the efan that thing was too small.
however, I use the same one and you can open it up and basically "double up the copper laminations".  I liked it because of its small profile.
I would rather have a long 10pos distribution block which I have now found, home made.
great work!!!
and that spoiler,, what are the odds of them still having it!  nice work
Reply #176
Started making a panel for the rear deck and rear seat delete.  Waiting on next little bit of cash to save for brake lines, bumpsteer and sway bar links.
X
X
X
Reply #177
I ordered the front stainless brakes line this morning, MM-MMBK8F kit
Reply #178
Installed the lines yesterday
X
X
X
Reply #179
Thats a whole lotta red allllllllllllll over that car. Looks good though keep up the good work bud
