Topic: Shuddering engine...UPDATE July,1 (Read 19520 times) previous topic - next topic
Reply #45
It looks like there should have been one from the factory. There's a raised section in the trunk right over the sending unit.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Reply #46
Yep, I cut it, and felt good about it, and never looked back. Swapping a pump in less than 10 minutes, taking my time, with a full tank of gas, does not hurt my feelings (if it has to be done at all). With the panel installed to cover the hole, and the carpet in place, nobody would ever know. Tomorrow I'll be back out looking for the problem. Working all weekend. I got the 9 volt for the code checker, and that will be the first step of business tomorrow after the gym.
Reply #47
Going out as soon as the sun comes up. Then, I WILL figure the issue out TODAY !!!!
Reply #48
Still no codes. ran out of time today. Swapped the fuel pump and distributor (that took all of 20 minutes) reset the timing to 12....no change. I haven't had time to pull the headers so I can pull the plugs. Too much going on. It may be time to trade the old girl in on something newer. I seriously did talk to Gayle about it. I have little things going on all the time, and for the last few months, no time to be wrenching on little . Man, tired of little  to deal with. 5 minute jobs to fix, but forever in diagnosing. No funds for it either. All funds are tied up in the house, new deck, school stuff for the youngest and on and on. Will I keep the car? Probably, but for the first REAL time ever, I'm having thoughts of letting her go. I gotta get some time to do some real thinking about it.
Reply #49
Quote from: vinnietbird;392654
Vinnie, I think you may have a temperature, you should go lay down for a bit...
Reply #50
I'm just about at the end of my patience with the little BS  that happens every 4 months. For the first time ever, I am feeling that I can let go, and still sleep at night.
Reply #51
Does this only happen at wot under load Vinny?  Or is it rpm based?
Reply #53
Vac lines?
Reply #54
Quote from: Bob;392660
At idle, it's right about 950....just as always, smooth as it always is (for the TFS-1 cam). Once I push the gas, whether in neutral or in gear, the vibration/shudder/ whatever starts. It's not an earth shaking thing, but I can feel the stammer in the car.
The TPS and IAC were swapped a few minutes ago before I came in from watering the yard. No time to drive it yet and see where it stands after those parts were changed. I am trying to find time to pull the headers and check the plugs. The simplest parts to check first, but a job to get to.
The vacuum lines all checked good. I went through every one of them, twice.
I gave the harmonic balancer a look over from all angles I can see from, and the rubber is good, and it APPEARS to be good. It's less than two years old, and MAYBE 20,000 miles on it. Not that always means anything.
Swapped parts...
_New fuel pump
-New Coil
-New TFI module
-my extra distributor (known good, was on my E-303 engine)
-timing at 12
This wasn't happening Saturday, then all of the sudden it started Sunday (a week ago, not yesterday).
Tomorrow, one way or another, I'll run codes, and go from there. If time allows, I'll pull the plugs. Hopefully.
Reply #55
Did you run the cylinder balance test and pass?
Reply #56
I have honestly never heard of the balance test until this thread.....
Reply #57
Oh, and the test plug under the hood....there's only the bigger plug, not the smaller one. Strange, my last two Birds (both '88's as well) had the smaller plug also. This car...MIA. I can't find any broken wires, no sign it was ever there.
Reply #58
You should run it vinny, it will cut one cyl at a time and let you know if one of them is not contributing to the idle speed..
What do the plugs look like?
Reply #59
I hope to pull the plugs tomorrow. haven't had time to pull the headers to get to them yet.
How do I do the test?
