Topic: Shuddering engine...UPDATE July,1 (Read 19552 times) previous topic - next topic
Reply #75
Coil? I know its not even remotly close to the same car but my buddy had a 97 cobra that had a studder traced it down to being a coil pack. maybe?
Reply #76
What does it mean that the wires look good? Visually, or with your ohm meter?  And make sure that 7 and 8 are an inch apart. (That last bit came from the field service engineer running the advanced driveability class I'm in this week)
Reply #77
I have a brand new coil.
I think I may have it figured out.....stay tuned.
Reply #78
Quote from: vinnietbird;392735
New problem. I don't know how to check the codes. My car isn't equipped with the small plug with the single wire. Only the larger plug.
look around it might be tucked under something,  is that your original harness?
Reply #79
Yes, original harness. No small plug anywhere. I can't even find a broken wire where it MIGHT have been.
Reply #80
Quote from: TheFoeYouKnow;392738
The wires looked good in appearance from end to end..... Upon further inspection, when twisted, one has a slice in the boot at the plug. Swapping wires. Stand by for an update.
Reply #81
Quote from: TheFoeYouKnow;392681
It's probably easier to swap the wires, than to pull the plugs, vinnie.  Start easy, work up to the hard stuff like plug pulling, especially with P heads.  Save yourself some frustration.
+1
Reply #82
Did you read post 63?
STI is a R/BK wire
If the STI is in the large connector you may have to back it out of the connector to hook it to your code reader.
Reply #83
I'll check that shortly. New wires installed, no change.
Reply #84
O.K !!! Got the codes......at least I think I did....the numbers (beeps) went as follows...
9, 5, 9, 5, 1, 9, 5, 9, 5
According to the book I have, 95 is the fuel pump secondary circuit open.....What the "bleep" is that?
Reply #85
I think the "1' in the middle is the separator code.
Reply #86
Quote from: vinnietbird;392763
Correct. It seperates the on demand codes from the memory codes.
What I think you have, and someone will correct me if I am wrong, is you have upgraded to mass air and the stock 87 cable harness does not have the fuel pump monitor wire to EEC pin 8.
Since the pump runs you can ignore the code.
Now run the KOER test. When it finishes outputting codes, momentarily go to WOT and it should start running the cylinder balance tests.
Reply #87
Give me a little more details on this "KOER" test please, and the cylinder balance test.
Reply #88
oh yes, and my car is an '88, not an '87.
Reply #89
Tomorrow, after work, I'll do the KOER test. I think I can do that. It has the instructions in the book. I'll update tomorrow after work.    !!!!!!!!!!!!!!!!!!!!
