Topic: Shuddering engine...UPDATE July,1 (Read 19673 times) previous topic - next topic
New gas. My daily driver. As far as it being a 5 minute fix, I agree. It's the "figuring out what it is" part of it. Getting ready to go drive it to the gym and I'll see if the distributor module swap helped at all.
Coil was still under warranty (sweet !!!), so, I swapped it out. Still having the same issue. Going to run codes shortly, then go from there. After that, I'll pull and check the plugs.
Quote from: mcb82gt;392292
Bad / old fuel?
Very possible i am going through this now as we speak.
I fill the tank every two weeks.
Then you fuel is most likely OK. Just a thought!!
Do a cylinder balance test with the EEC..
Quote from: Haystack;392273
Run the ccodes. If it sennsor related, it should have a code either stored in continous memory, or as an active code. If its a sparkplug/fuel injector/ compression problem, it should show up in a cylinder ballance test. If nothing comes up, then you start hitting general matinence things.
First step should always be codes though.
Just read the other pages after I posted lol... Yeah haystack has the right idea IMHO
Quote from: vinnietbird;392298
Sorry.  I guess I didnt know that was your DD.
Mike
Got busy in the back yard preparing to build a deck. Gotta get a 9 volt battery tomorrow for the code checker. Stay tuned.
Reply #39
Fixing the shudder, that would be a great b-day gift... would it not?  Hoping you get it.
Mike
Reply #40
Can't work on it til Monday. My next day off. . Starting with the codes, then plugs if necessary. May swap the fuel pump just to see. I have a new one as back up.
Reply #41
I hope that before you resort to all the work in dropping the tank, you'll try something simpler.  Like testing your wires.  It would take less time to prove me wrong than to prove everybody else right.
Reply #42
I have a fuel pump access panel in the trunk. Takes 5 minutes to swap the pump.
Reply #43
VINNIE YOU CUT YOUR CAR UP~~~~~ SHAME ON YOU!!!! Just kidding. A quick fuel delivery check is all that is necessary. Volume Pressure ETC!!
Reply #44
An access panel...  no kidding.  That sounds like a good idea, I've got to drop my tank and replace it (broken baffles).  After I repair the right strap mount (rotting off), I might see about an access panel myself.
